Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree2Likes
Thread: Can't dimension to centerline of door
    May 18, 2011
    Calgary, AB
    401
    05:41 PM
    I'm stumped why on earth when I try and dimension to the centreline of the parent door family, it's offset in the project but in the family it appears to be fine.
    I can grab the frame centreline, but that won't let me "Equal" the dimension string and centre the door between two walls.
    Attached Thumbnails Attached Thumbnails Can't dimension to centerline of door-door_plan.jpg   Can't dimension to centerline of door-door_inplace.jpg
    Attached Files Attached Files
    Member jasonbailly's Avatar
    December 20, 2010
    Portland, OR
    122
    11:41 PM
    The nested door panel family that is being controlled by the "Panel_1_Type" Family Type Parameter is not aligned and locked to a horizontal and a vertical Reference Plane. I did so in plan and it now dimensions as expected.
    Mr. Revit OpEd
    2,879
    04:41 PM
    The Center (Left/Right) RP is there, just have to move the cursor toward the inside edge of the door in the middle so the RP Jason mentions doesn't compete with selecting it.
    Attached Thumbnails Attached Thumbnails Can't dimension to centerline of door-rpcl.jpg
    May 18, 2011
    Calgary, AB
    401
    05:41 PM
    Thank you for having a look.
    @Jason is that reference plane coming from the parent family or is it from the frame? I aligned and locked the panel, but that's not making a difference.
    @Steve Yes, that's the RP from the frame, unfortunately I can't use that to centre the door between two walls, I get an error (sorry, the title of the post was a bit misleading)
    Huh. I imported a CAD file to determine the origin, and the family is built off-centre. But I don't get the same dimensions as I posted. It's a mystery RP in there somewhere.
    Mr. Revit OpEd
    2,879
    04:41 PM
    Okay - Edit the family - Change the panel width via the dimension string to 1000. A warning appears > click Remove Constraints. Load the family back into the project and it should allow for EQ constraints and you'll find the dimension recognizes the correct Center (Left/Right) RP.
    May 18, 2011
    Calgary, AB
    401
    05:41 PM
    Quote Originally Posted by Steve_Stafford View Post
    I don't get any warning when I change the width using the dimension string. Everything flexes as expected.
    Mr. Revit OpEd
    2,879
    04:41 PM
    I was using 2018 which seems more fussy about constraint issues.
    Mr. Revit OpEd
    2,879
    04:41 PM
    Use Select by ID - enter ID 3962748 and Delete it. Reload it into the project and it should work. Just did for me in 2017.
    May 18, 2011
    Calgary, AB
    401
    05:41 PM
    Oh man... "the following Element IDs are invalid and won't be used". Somewhere between the one I posted and all the mucking around it's not there.
    Playing with the door in the project, I selected the Center (left/right) reference plane then unlocked it. It moved the doors in the project, but it's now dimensioning correctly.
    Hopefully that solves the issue.
    Thank you for the trouble shooting.
    Mr. Revit OpEd
    2,879
    04:41 PM
    Cool, yeah I think the constraint was associated with the Center (Left/Right) reference plane and it was prevent it from shifting properly. Once the locked is removed it reconciled where it was supposed to be. That family is a bit of a mess structurally...along the lines of Bones, Muscle and Skin.
  1. Dimension to linked file wall core centerline???
    By kwandrew2 in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2017, 10:56 PM
  2. Dimension of Curtain door in Door legend
    By phamtuan in forum Architecture - Family Creation
    Last Post: March 29th, 2013, 04:32 PM
  3. Dimension to Centerline
    By DaveP in forum Tutorials, Tips & Tricks
    Last Post: March 26th, 2013, 03:35 AM
  4. How to annotate centerline-to-centerline piping?
    By lukewallace1990 in forum MEP - General
    Last Post: February 28th, 2013, 05:46 PM
  5. Dimension to Centerline
    By DaveP in forum Architecture and General Revit Questions
    Last Post: January 31st, 2013, 03:31 PM
