Results 1 to 4 of 4
Thread: Why when I Rotate Project North do some families not rotate?
    Junior Member jstewartarch's Avatar
    August 21, 2012
    Atlanta GA
    8
    01:34 PM
    Why when I Rotate Project North do some families not rotate? For some reason I have a family of a nested table and chairs and it will not rotate. Also a bunch of other random families a drinking fountain, sink, roof drains and a few other random families.
    Is there a rhyme or reason to the madness?
    Thanks,
    Jennifer
    Attached Thumbnails Attached Thumbnails Why when I Rotate Project North do some families not rotate?-rotating-families.jpg
    May 2, 2013
    1
    10:34 AM
    for me it seems that families that are hosted to face will not rotate but families that are hosted to workplane do, unfortunately the default behavior in Revit is to place families (especially furniture) to face, have to remind myself to change the placement to work plane before placing EVERY TIME (wish list item)
    Gold Coast
    2,621
    03:34 AM
    Quote Originally Posted by dnikandjam View Post
    OR use unhosted families
    Mr. Revit OpEd
    2,882
    10:34 AM
    In-Place and Face Based families are most vulnerable because of their hosting work-planes. Want to see how Rotate Project North (RPN) will do with your family? Use the Rotate tool and place the rotation origin well away from it. Does it rotate as expected or does Revit let you at all? It's not utterly predictive but if that doesn't work...RPN definitely won't.
    RPN is the same as if we select everything (all model and annotation elements in all views) in the model and then try to Rotate it all together.
  1. Rotate Project North
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: July 27th, 2018, 04:18 PM
  2. Rotate Project North Issue
    By Brocha in forum Architecture and General Revit Questions
    Last Post: June 10th, 2017, 04:09 AM
  3. Rotate Project North
    By krickabaugh in forum Architecture and General Revit Questions
    Last Post: March 10th, 2017, 09:55 AM
  4. Rotate Project North tool rotating True North
    By rkitect in forum Architecture and General Revit Questions
    Last Post: March 20th, 2013, 01:51 AM
  5. scope box and rotate project north
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2011, 06:04 PM
