Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree1Likes
Thread: How to Cut the family in nested family
    November 6, 2014
    9
    01:26 PM
    Exclamation How to Cut the family in nested family
    Why I can't cut a generic model family when it's loaded into the other generic model family. I have checked the "cut with void when loaded" box.
    Gold Coast
    2,609
    11:26 PM
    Cuts with void when loaded is an ambiguous parameter name. It means a 'void' in the family will 'cut' when it is 'loaded' into a project.
    As for your nested gm not cutting you might need to check its geometry visibilty settings and see if 'when cut in plan' is checked and maybe make it shared as well (not near revit atm).
    November 6, 2014
    9
    01:26 PM
    Thank you Elton, I'm just not clear how can I cut a generic family in family not in project.
    In fact, I have loaded many extrusion families into a new generic family. then I want to cut or punch them in this new family. Is it possible or not??
    Gold Coast
    2,609
    11:26 PM
    You can adjust the cut plane in plan views in familes. Hit the drop down menu just below the type selector and switch to your reference view. Your properties will then be populated with the view parameters, including view range. Note this has no effect on view ranges in a project.
    November 6, 2014
    9
    01:26 PM
    Sorry, maybe you didn't get my point. In short, I need to cut family with void forms in 3D view.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    09:26 AM
    Use a face-based template or build the voids into the family you are making. Can't suggest with since not sure what you're trying to accomplish.
    November 6, 2014
    9
    01:26 PM
    Ok, I will explain step by step.
    1) create two generic model families, one is named "Family1", the other is named "Family2".
    2) create any solid form in "Family1", then Load "Family1" into "Family2" and place it.
    3) create any void form in "Family2" .
    4) use the void form to cut "family1". (This's what I need.)
    Kingdom of Denmark
    4,221
    03:26 PM
    "Cut with Voids When Loaded" only works when the family is Loaded into a PROJECT, not when Loaded/Nested into another FAMILY. So sorry, that´s not gonna work.
    cganiere likes this.
    November 6, 2014
    9
    01:26 PM
    It's really disappointing. Right now, I am cutting the nested family in project with void form one by one.
    Gold Coast
    2,609
    11:26 PM
    Quote Originally Posted by LevinLu View Post
    So build the void in the family ie. not nested.
  1. Family Editor changes 2012 - 2014. Constraint to nested family broken.
    By Duncan in forum Architecture - Family Creation
    Last Post: May 4th, 2017, 10:35 PM
  2. Replies: 15
    Last Post: March 5th, 2017, 05:01 AM
  3. Face Based Family with only a Void Nested into a Generic Model Family
    By Joshua Kohl in forum Architecture - Family Creation
    Last Post: October 18th, 2016, 02:12 PM
  4. Replies: 5
    Last Post: April 2nd, 2014, 07:59 PM
  5. Nested adaptive component family wont flex in parent family (Revit 2013)
    By Steve_Bennett in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 22nd, 2014, 11:45 PM
