Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By cellophane
Thread: Sloped floor opening family
    May 5, 2016
    6
    02:18 PM
    Unhappy Sloped floor opening family
    Hello, again I've got a question about opening families.
    Is there any way to create a family that will cut sloped floor in vertical axis and ensure proper working of "invisible line underlay trick"?
    If I create wall based gm, and untick "always vertical" it's axis is going to rotate perpendicularly to the host floor and then invisible line trick is going to fail. It's just not showing underlay, what is logic.
    So can i create any "always vertical" family that will work with sloped floor host?
    I just thought about sth during that typing...
    Will combination of "always vertical" underlay child family, and non "always vertical" opening parent fimily work if nested? Or parent family will override vertical properties of nested family?
    Cheers
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    10:18 AM
    Use a face-based family and you can host it to whatever object type you want For a floor (roof or ceiling) you can also use the Vertical Opening (or shaft if it needs to cut multiple levels) to get your cut as well. Help
    Andres Franco likes this.
    May 5, 2016
    6
    02:18 PM
    I was thinking about face-based family, but still, will invisible line trick work with it?
    And the problem with fb family is that it wont fit to floor's thickness. So you have next parameter to contrlo if you dont want your void to stick out of the host floor.
    What's more, I need a family. I want to tag it with shared parameters that I could instantly get dimensions of it.
    Anyway. my idea about nested family was stupid... After all child family will be based at floor based family plane, so it will we "vertical" to the floor... :P
    August 9, 2011
    Louisville, KY
    6,104
    10:18 AM
    I'm not sure which invisible line trick you are referring to
    May 5, 2016
    6
    02:18 PM
    Ha! I got it! I just had not to lock my void to floor. I left it extended over/under floor levels. Now with "always vertical" tick it's cutting sloped floors in vertical axis and invisible line trick is working well
    Thx for your effort cellophane
    Well im talking about that trick http://revitrocks.blogspot.com/2012/...ine-trick.html
  1. Structural Area Reinforcement: SLOPED Floor, Rebar is OUTSIDE the floor?
    By doni49 in forum Structure - General Questions
    Last Post: April 11th, 2016, 12:47 PM
  2. Sloped Curved Floor
    Last Post: January 14th, 2016, 02:30 PM
  3. Help with Sloped Floor that Drops off and connects to the top of first floor
    By onlyarmani in forum Architecture and General Revit Questions
    Last Post: June 5th, 2015, 03:01 PM
  4. Attach column to sloped floor
    Last Post: March 8th, 2013, 09:13 PM
  5. Is in NOT possible to place a "Floor: Slab Edge" on sloped on a floor?
    By pixelforce in forum Architecture and General Revit Questions
    Last Post: February 15th, 2013, 11:57 PM
