Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Robin Deurloo
Thread: Labels
    April 24, 2018
    31
    12:55 PM
    Labels
    Is it possible to add a label to a detail component (example: 2X4 wood side view) that changes depending on the length of the stud. So if my detail component was 4 feet long, my label in the family would read as 4 feet?
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:55 PM
    Yes, nest a generic annotation with a label in your detail item and link the parameters from the label to the ones from you detail item.
    Small example is attached
    Attached Files Attached Files
    cganiere likes this.
    April 24, 2018
    31
    12:55 PM
    Worked great! Thanks
    July 7, 2011
    Rotterdam, Holland
    1,235
    07:55 PM
    Good to hear !
    April 24, 2018
    31
    12:55 PM
    Okay one more question for you, I typically use a tolerance of up to 1/16", this label seems to want to read up to the 1/32". I change the settings in the label, load it back into the family and overwrite the parameters and it works fine, but when I load and overwrite back into the project, it goes back to a 1/32". Any suggestions?
    EDIT: Per usual I find my answer a minute after I ask the question, just had to load the family all over again and it seems to work
  1. Labels
    By Dr2430 in forum Architecture and General Revit Questions
    Last Post: April 24th, 2018, 07:21 PM
  2. Sticker/Labels
    By Saldambro in forum MEP - General
    Last Post: February 21st, 2017, 11:20 PM
  3. Can't get rid of labels
    By Tom Dolle in forum Architecture and General Revit Questions
    Last Post: October 12th, 2012, 07:29 PM
  4. Drawn By Labels
    By domsib in forum Architecture and General Revit Questions
    Last Post: August 21st, 2012, 01:27 PM
  5. Stair labels
    By chris.macko in forum Architecture and General Revit Questions
    Last Post: March 16th, 2012, 09:58 PM
