Results 1 to 10 of 10
Thread: Section Tag does display properly in elevation view, but displays correct in plan
    July 19, 2018
    13
    10:12 AM
    So I made my own section head family, and it displays properly in plan view but not correctly in elevation views. The lines that separate drawing number and sheet number are rotated.
    Attached Thumbnails Attached Thumbnails Section Tag  does display properly in elevation view, but displays correct in plan-capture-1.png   Section Tag  does display properly in elevation view, but displays correct in plan-capture.png
    Attached Files Attached Files
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,949
    09:12 AM
    Lots of threads here about that.
    Just do a search (upper right) for "section head"
    Oh, And welcome to RFO!
    July 19, 2018
    13
    10:12 AM
    lolol feel like a newbie, I knew i should've done that . And thanks dawg! I plan on lurking here for a while.
    July 19, 2018
    13
    10:12 AM
    I know this is noob, but I couldn't find threads about that on forum.
    January 10, 2011
    St Paul, MN
    2,949
    09:12 AM
    July 19, 2018
    13
    10:12 AM
    Link didn't work, I attached a screenshot if you don't believe me. Anyways I figured it out, but my method is ghetto. I copied the middle line from the original section head family. I noticed that line in properties has a "Yes/No" parameter in the "Other" section called "Rotate With Section" which is un-editable, and is checked. (To me that makes no sense because if anything, according to the name it would be unchecked, but whatever) Lets say I did not have the original section head family, how would I create that type of line from scratch? Sorry I am not trying to be annoying, but I rather clear this up now rather than next time I come across a brick wall
    Attached Thumbnails Attached Thumbnails Section Tag  does display properly in elevation view, but displays correct in plan-capture.png
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    07:12 AM
    Quote Originally Posted by upyoas View Post
    well, I tried to find the original post that contained a Section Head family that will rotate as you want and failed. So, I am posting my family that I pilfered from that thread from a couple of years ago. Thanks to cellersick (IIRC) for the original! I didn't know what version of Revit that you are using so the attached family is R2016 so you can upgrade it to where ever you are.
    July 19, 2018
    13
    10:12 AM
    Thanks! I saw its made a bit different than mine and default Revit one. Lol bumping my question to bottom of thread though, anyone know anything about the "Rotate With Section"Parameter of the middle line in the section header? And how to add it without copying it from Revit's original section head family?
    10,036
    09:12 AM
    July 19, 2018
    13
    10:12 AM
    Bumping this up a little to see if any one knows anything about this mysterious "Rotate With Section" parameter. I am confused how supposedly same object (Line style) has different parameters. I attached 2 screen shots bellow, showing different parameters in properties for 2 drawing lines with same line style. Now the section head I have now works fine (and without the underline cheat), its just not knowing this causes me not to sleep at night (And I'm sure I will regret avoiding this now).
    Attached Thumbnails Attached Thumbnails Section Tag  does display properly in elevation view, but displays correct in plan-c2.png   Section Tag  does display properly in elevation view, but displays correct in plan-c1.png
  1. Different elevation points in section and plan
    By jgardner in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2016, 08:07 PM
  2. Changing the Plan and Section/Elevation Representation of trees?
    By gooner442 in forum Architecture and General Revit Questions
    Last Post: December 9th, 2014, 10:24 AM
  3. graphic display in 3D-Section-View
    By poomon in forum Architecture and General Revit Questions
    Last Post: June 17th, 2013, 01:24 PM
  4. Replies: 0
    Last Post: June 7th, 2013, 04:15 PM
  5. How to view Section view lines on a plan view bigger than 1:100 scale
    By eks_al in forum Architecture and General Revit Questions
    Last Post: January 18th, 2012, 12:41 AM
