Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By cellophane
Thread: Customized View Title
    March 19, 2015
    9
    05:32 PM
    Greetings all!
    I have been tasked with creating a revit template for the planting plans we do and I have gotten stuck when it comes to taking the view title OOTB and editing it to what I need for the planting plans. I have enclosed our existing view title and the desired view title. I can not seem to find a way to incorporate the features I need into the family. I added shared parameters for the project location and issue date, but how can I get the labels to line up the way my example shows? I tried editing the view title to just include the title and add the additional information using a line-based family, but those families can not be added to the sheet only views. Has anyone done something similar that could give me some other ideas? any and all suggestions are welcome. Thank you all for your time and I look forward to your replies.
    Attached Thumbnails Attached Thumbnails Customized View Title-planting-plan-existing-view-title.png   Customized View Title-planting-plan-desired-view-title.png
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,489
    04:32 PM
    Quote Originally Posted by M_tuter_97 View Post
    Greetings all!
    Open the stock View Title family and do a Save As. Add shared parameters for Location, Date, and use the existing View Name and View Scale parameters. Add labels for location and date and put them where you show them in the View Title family. I don't know what font that is but assuming that it is in your Revit template just edit the font style in the tag type properties to that font style. If you don't want a view number (???) then delete that from the family. Underlines are always an issue and I don't use them so you can do a search in the forum for tag underlines as this has been discussed in the past.
    March 19, 2015
    9
    05:32 PM
    Dave,
    Thank you for your response. I did just as you suggested and it worked. Currently I will leave the underline out of the family and the user will need to add the line separately.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    07:32 PM
    You can group your label with a reference line and then constrain the line. The OOTB view label line is basically the width of the view; to counter that I've got mine set up with fixed lengths.
    Attached Files Attached Files
    cganiere and Dave Jones like this.
  1. View Scale/View Title Coordination
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: October 7th, 2017, 06:16 AM
  2. view title on sheet won't show until second view is placed
    By elton williams in forum Architecture and General Revit Questions
    Last Post: November 24th, 2014, 07:21 AM
  3. View Vort or View Title Extension line
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2013, 02:23 PM
  4. View title
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: July 25th, 2011, 05:48 PM
  5. Display scale on a view title of a 3D view?
    Last Post: July 12th, 2011, 08:46 PM
