Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By jmk
  • 2 Post By BLothian
Thread: Wall based generic model - Height parameter
    May 5, 2016
    6
    02:02 AM
    Question Wall based generic model - Height parameter
    Im facing with problem that i can not beat, despite the fact that Ive read a lot of post.
    Im working on walls openings right now.
    The family ive attached used to be with shared parameters.
    My x parameter, that is result parameter, schould control geometric heigth, but when loaded to preject the only way to control it is by elevation parameter
    Family has some weird stuff, like Opening_Top,mid,bot parameters. Its problem slover of working with different construction industries. Some of them mesure their opening elevations to the bottom edge, others to the top.
    The Opening elevation value is measured from 00 level
    Important parameter is yes/no "Storey_above_00" it changes calculation rules.
    So, if electricity opening at the bottom edge is -80 and my Storey_elevation is -350 my famili calculate elevation from -01 lvl to the bottom edge (270), but i have to change elevation manualy. The x parameter is not "overriding it".
    Any ideas?
    Attached Files Attached Files
    February 5, 2012
    47
    02:02 AM
    I'm on an iPad right now but I noticed recently that if I associate my top of opening dimension to the reference PLANE that sits at the same height as the LEVEL in a WB family that it works as expected. Using the level ends up ignoring the height in the family environment.
    Sent from my iPad using Tapatalk
    May 5, 2016
    6
    02:02 AM
    Well, Sir it doesn't work maybe I should rework whole family, and start with that guidelines. But I would rather not.
    February 5, 2012
    47
    02:02 AM
    Can you post your family please?
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    08:02 PM
    To control the placement height of a floating object hosted on a wall I think I end up putting in an invisible line extending from the reference level to the desired height every time, otherwise its sits the bottom of the object on the level.
    DavidLarson likes this.
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    465
    02:02 AM
    Also, ensure you place a ref plane the bottom of the wall, tick 'defines origin' and set your opening top parameter to it and your upper ref plane. I've done precisely this for a wall opening family and it works perfect but, without the ref plane at the base it doesn't and the default 'Elevation' instance parameter kicks in (even with the invisible line trick).
    jmk and Algali like this.
    May 5, 2016
    6
    02:02 AM
    Yes, that's it! Thank you all so much!
    Im using "invisible line trick" to see opening's boundaries. So the problem was to tick origin at proper ref. plane.
    I had to set "basic" ref. plane as an origin. Now it works excellent.
    I had played with origin set, but I think I messed sth up :/
    Thanks again.
    Ps. Can't u see my family? I have attached it to my 1st post.
  1. Sign ceiling based (generic model) below distance from level - PARAMETER
    By allan120791 in forum Architecture - Family Creation
    Last Post: March 8th, 2016, 12:14 AM
  2. Floor based generic model - how to get dimension parameter into schedule?
    By therkelsenmeister in forum Architecture and General Revit Questions
    Last Post: January 28th, 2016, 02:15 PM
  3. Creating a floor based and wall based generic model in a single family
    By PraveenPonnuru in forum Tutorials, Tips & Tricks
    Last Post: September 10th, 2015, 04:16 PM
  4. Generic model wall based
    By dmodomino in forum Structure - General Questions
    Last Post: August 27th, 2015, 07:35 PM
  5. Generic model wall based
    By bangobeat in forum Architecture - Family Creation
    Last Post: July 29th, 2011, 06:25 PM
