Results 1 to 1 of 1
Like Tree3Likes
  • 3 Post By Andrew K
Thread: Glazing Grid Families
    Senior Member
    August 19, 2011
    New Hampshire
    503
    02:07 PM
    Hello again,
    I wanted to share some generic glazing grid options I've been working on.
    To properly use these families, you will need the five parameters shown in the 'Grid Parameters' attachment below.
    The options include:
    Standard : Default colonial grid. Also the option to use for 'no grid'. Currently does not visibly remove the grids until both 'Grid Counts' are set to 0 as
    a safety check measure. Can also function as only horizontal or only vertical. Auto Spaced.
    Prairie : Default Prairie. Requires the 'Grid Spacing' parameters to determine the look.
    Perimeter : Default Perimeter. Requires the 'Grid Spacing' parameters and types to determine look. For Hung / Multi-stack Picture / Slider windows
    that want the Prairie look, but stretched over two sashes.
    Craftsman : Single horizontal grid with single / multiple vertical grids. Requires the 'Grid Spacing' parameter and 'Grid Count' parameters.
    Family covers both SDL and GBG variations. GBG shows in elevation using model lines. SDL do not overlap in elevation views, so no squares of lines at every grid intersection.
    Interior / Exterior color capabilities.
    Does not show in plan by default.
    Let me know what you think!
    Attached Thumbnails Attached Thumbnails Glazing Grid Families-grid-parameters.jpg   Glazing Grid Families-hung-prairie.jpg   Glazing Grid Families-hung-perimeter.jpg   Glazing Grid Families-hung-craftsman.jpg   Glazing Grid Families-hung-colonial.jpg
    Attached Files Attached Files
  1. Site Grid vs Floor Plan Grid
    By SHAC01 in forum Architecture and General Revit Questions
    Last Post: March 27th, 2017, 09:03 AM
  2. Replies: 0
    Last Post: October 7th, 2016, 12:15 AM
  3. Customizing Grid Line Symbol and Grid Head Families
    By thaihoalu in forum Architecture and General Revit Questions
    Last Post: November 19th, 2014, 04:30 PM
  4. Curved Curtain Grid on Sloped Glazing
    By npalmitessa in forum Architecture and General Revit Questions
    Last Post: March 26th, 2014, 06:01 PM
  5. Scale-adjusting Level/Grid Head Families
    Last Post: April 24th, 2011, 11:33 AM
