Results 1 to 6 of 6
Like Tree3Likes
  • 2 Post By Robin Deurloo
  • 1 Post By Robin Deurloo
Thread: Sliding door
    October 20, 2017
    9
    03:06 PM
    Sliding door
    I have little problem
    i was create sliding door but last parameter i dont know how to do it
    its open close parameter (yes/no)
    how to manage this parameter, when the box is checked its open the leaf its move to one position
    when is the box empty then leaf is in close position its on other position
    any help
    thx
    Attached Files Attached Files
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:06 PM
    Without seeing your family I would sugest the following.
    Make a parameter called 'open' (yes/no)
    Make a parameter called 'open_dim'
    In that last paarameter put a formula IF(open,900,0) This would make the dim 900 if open is ticked and 0 if not
    Add ref planes and put all the dimensions and parameter to them and link the door to that ref plane.
    names can be different of course.
    Did not try it, but this is from the top of my head.
    Andres Franco and cganiere like this.
    October 20, 2017
    9
    03:06 PM
    see my revit familiy door i need to "move" sash on left side but i stuck using parameters
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:06 PM
    This is what I would do (very quick and dirty)
    One of the doors would be fixed I asume, so fix that (the one on the right in this case)
    the other would be movable, so make a ref plane with a parameter (your dw) and lock the moving door to that.
    Now you can move the moving door with the dw parameter.
    I did remove a formula from the dw parameter and changed the width sash_01 to a type parameter
    cganiere likes this.
    October 20, 2017
    9
    03:06 PM
    that is not what i mean
    I mean like schueco sliding door 75 you can find on this address
    https://bimobject.com/en/schueco/pro...de_easy_access
    but i cannot do like schueco on easy way
    they have "vent open" parameter (yes/no) whey u click sash move on x and y coodinates
    all I need is move by x coordinates
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:06 PM
    Then I must be misunderstanding you.
    But I do see I have used the wrong parameter in the family I posted for the open bit. Add the Open_Dim to to dimension instead of the dw and I think it should word as you want, again, unless I really misunderstand you.
    The Schueco window is just a lot more complicated, but works in about the same way as the example I posted.
  1. Curved Sliding Door
    By vivek in forum Architecture and General Revit Questions
    Last Post: September 20th, 2016, 02:45 PM
  2. sliding pocket door
    By marafigo in forum Architecture - Family Creation
    Last Post: February 11th, 2015, 11:30 AM
  3. automatic sliding door family
    By andreakset in forum Architecture - Family Creation
    Last Post: April 24th, 2013, 04:18 PM
  4. How do I add a sliding door into an existing curtain wall ? How to make
    By raincatsdogs in forum Architecture and General Revit Questions
    Last Post: November 21st, 2012, 12:34 AM
  5. 6 Panel Sliding Glass Door
    By tomcott in forum Architecture and General Revit Questions
    Last Post: September 23rd, 2011, 07:01 PM
