Results 1 to 3 of 3
Thread: Structural Framing - Beam Auto-Joining
    April 7, 2018
    19
    03:06 PM
    I have a structural framing family which I downloaded and have adapted to suit our needs.
    The family is a metal webbed joist and I've had no issue with it previously as obviosuly a joist is spaced apart from each other.
    What I am needing to do is place them end to end but with a tolerance gap of 18mm. If i move it to the desired location the joist automatically joins with the next one, without our desired tolerance. The family doesn't have the 'disallow join' on the end node, instead it has the 'drage generic curve driven component'. I can't seem to get around this issue.
    Is there anything I can do to stop it connecting automatically?
    Senior Member
    December 16, 2010
    849
    12:06 AM
    maybe link your family up here and I will have a look at its behaviour?
    April 7, 2018
    19
    03:06 PM
    Quote Originally Posted by Karalon10 View Post
    Hi, sorry i managed to get around this by moving the beams/framing off centre from each other, but not the best workaround.
    I'm now looking at this again, and having to use beams end to end with a gap, but it's auto joining. See link below to family that I am using. https://we.tl/MYYOi1TiP0
  1. Invisible Structural Framing/Beam when Rendered
    By grafista in forum Rendering and Gallery
    Last Post: June 1st, 2017, 03:09 AM
  2. How do I modify (or turn off) the structural framing auto-join feature
    By ecraider in forum Structure - Family Creation
    Last Post: February 23rd, 2016, 07:18 PM
  3. Structural Framing Plan-Coarse view, Joist gap at beam
    By Revit3d in forum Structure - General Questions
    Last Post: January 20th, 2016, 09:38 PM
  4. Joining roof/floor & structural framing
    By Cyus in forum Architecture and General Revit Questions
    Last Post: March 1st, 2015, 11:55 AM
  5. Generic model and structural framing beam and braces familes
    By simon1688 in forum Architecture - Family Creation
    Last Post: March 31st, 2012, 10:26 PM
