Results 1 to 5 of 5
Thread: custom baluster with decorative piece not staying equal 2019
    June 26, 2014
    87
    04:29 PM
    i am trying to replicate a baluster from an existing portion of a building that we are remodeling. it has a decorative piece in the center of the baluster equal from top & bottom. there is a similar baluster with same decorative piece that occurs twice in the baluster equal from top & bottom. i cannot get that decorative piece to stay equal when the baluster height needs to change. i am including an image of the existing baluster and the baluster family that i have started
    Attached Thumbnails Attached Thumbnails custom baluster with decorative piece not staying equal 2019-img_5587.jpg
    Attached Files Attached Files
    July 10, 2015
    Boise, Idaho
    663
    05:29 PM
    I would try making the center decorative piece a family on its own. Bring that in, lock it to the center of the baluster height. Then build the rest of the baluster off of that.
    For the baluster that has two of them, have it set so the inserted families are constrained off of the center.
    June 26, 2014
    87
    04:29 PM
    shall i create the center decorative piece family as a generic family or do suggest something else?
    July 10, 2015
    Boise, Idaho
    663
    05:29 PM
    Keep it all the same type of family but make the test object simple in case it doesn't work. Better to have it break with nothing special than to spend an hour modeling something that isnt' going to work
    June 26, 2018
    8
    08:29 PM
    Good Afternoon,
    I thank for group of the forum in receive me, and have a doubt about create a window with a side mirrored and a side normal, exist the possibility of be done ?
    I am beginner in Revit but i am enjoyng
  1. Replies: 0
    Last Post: May 2nd, 2018, 09:15 AM
  2. Loading custom baluster family adds duplicate parameters
    By nicklas.sand in forum Architecture and General Revit Questions
    Last Post: June 12th, 2015, 11:18 AM
  3. Baluster Railing - use Baluster Panel Family or Baluster Profile
    By trevorpan in forum Architecture - Family Creation
    Last Post: July 26th, 2014, 09:56 PM
  4. Decorative Cornice
    By Jamma79 in forum Architecture and General Revit Questions
    Last Post: January 13th, 2014, 03:29 PM
  5. Trouble staying logged in?
    By Darryl_S in forum Forum Suggestions and Feedback
    Last Post: January 10th, 2011, 10:46 PM
