Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: Shared Parameter spelling error
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,962
    09:28 PM
    I just realized I had a spelling error in a Shared Parameter I have loaded into a bunch of my families.
    I have corrected it in my SP file by renaming it in there.
    But when I re-load it into my family, it still comes in spelled wrong.
    I even tried to delete the parameter from my family and add it as a new parameter from the SP file.
    It still comes in spelled wrong.
    Is my only option to delete it completely from my SP file and make a whole new parameter, then delete the old one from my families (etc, etc) ?
    Gold Coast
    2,603
    12:28 PM
    Yes, thats your only option afaik. Completely replace it with a new parameter as revit remembers the old name. Unless theres some API or Dynamo way of doing it now.
    July 10, 2015
    Boise, Idaho
    651
    08:28 PM
    You don't by chance have two nearly identical versions of the same shared parameter in the file do you? I've had to edit the text file plenty of times due to fat fingering without any issue.
    10,100
    09:28 PM
    Ooooph. I also make a new parameter, then use Family Processor to add the new Parameter to all families, AND set the new parameter EQUAL to the old parameter, THEN have the FP delete the old parameter. Since the more recent versions of FP even let you control the processing order, you can do all of this in one batch, now.
    kowen1208 likes this.
  1. Replies: 0
    Last Post: January 12th, 2016, 05:45 AM
  2. Replies: 0
    Last Post: January 11th, 2016, 04:45 AM
  3. Shared Parameter Error
    By keusted in forum Architecture - Family Creation
    Last Post: July 15th, 2015, 01:31 PM
  4. shared family and <family type.....> parameter, when loaded error
    By Bross in forum Structure - Family Creation
    Last Post: November 25th, 2013, 11:56 AM
  5. Replies: 0
    Last Post: August 11th, 2011, 07:20 PM
