Results 1 to 1 of 1
Thread: Why is my curtain wall pattern based family behaving like this?
    October 8, 2012
    91
    02:58 PM
    Hi all
    I am making a family curtain panel family to recreate an actual panel. I have used Curtain Panel Pattern Based and the family flexes fine. It is orthogonal (all sides are at 90 degrees to each other) and are aligned to the grid. It is made by nesting a generic model into the panel family and aligning it to the grids. When I load the family into a mass surface with grids, it automatically gets rotated. (all images are attached)
    Can anyone help me find the cause and solution? I am also attaching the family where this error occurs. I tried attaching the sample project but the memory size exceeded the limit so was unable to.
    Thanks
    Virat
    Attached Thumbnails Attached Thumbnails Why is my curtain wall pattern based family behaving like this?-3d-view.jpg   Why is my curtain wall pattern based family behaving like this?-family-plan-view.jpg   Why is my curtain wall pattern based family behaving like this?-grid.jpg   Why is my curtain wall pattern based family behaving like this?-after-placing.jpg   Why is my curtain wall pattern based family behaving like this?-14.jpg
    Attached Files Attached Files
  1. Pattern Based Rectangular Curtain Panel - Split into Triangles based on Distortion
    By christianism in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 7th, 2018, 07:19 AM
  2. Replies: 2
    Last Post: January 26th, 2015, 01:57 AM
  3. Is there a way to schedule each panel in a Pattern Based Curtain wall?
    By viratmanchanda in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 22nd, 2014, 10:59 AM
  4. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
  5. Pattern based curtain wall problem. Revit 2012
    By Williamjcooper in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2012, 11:00 AM
