Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By MPwuzhere
  • 1 Post By Kate
Thread: Title block revision schedule visibility
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    411
    08:57 AM
    Is it the case that in my title block family I cannot put my revision schedule on a visibility parameter?
    I seem to be able to tie the visibility of all other elements (lines, text, labels, annotations) to a Yes/No parameter, but not my revision schedule. Is this possible please?
    Coeur d Alene, ID
    4,783
    03:57 PM
    I don't use any of the lines or text headers of the revision schedule as those are on the titleblock itself.
    anthonyB likes this.
    Junior Member Kate's Avatar
    September 4, 2014
    Ann Arbor, MI
    46
    06:57 PM
    To the best of my knowledge, it isn't possible to associate a revision schedule with a yes/no visibility parameter - nor is it possible to use a masking region or filled region to 'hide' the revision schedule.
    Instead you'll need to make a different title block family which doesn't contain the Revision schedule you don't want to see.
  1. How to add a field to the revision schedule in the title block template?
    By simon1688 in forum Structure - Family Creation
    Last Post: October 19th, 2015, 07:04 PM
  2. Title Block - Revision Table Text Problem
    By JPREng in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 09:44 PM
  3. Replies: 0
    Last Post: February 2nd, 2012, 02:15 PM
  4. Replies: 0
    Last Post: February 1st, 2012, 02:15 AM
  5. Revision block and title block
    By soboyle in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 09:22 AM
