Results 1 to 3 of 3
Thread: Is it possible to created 1D snap "point's" in families?
    May 15, 2018
    2
    05:39 AM
    I've been starting to make more and more families for work, and have just been making due with snap planes.
    I have downloaded the occasional family from various manufacturers, and sometimes there will be a 1-dimensional point, in the center of the family, that can be used to snap a dimension measurement to, from any angle.
    For the life of me, I can't figure out how to create my own version of this single-point snap location.
    Any suggestions or insights would be greatly appreciated.
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    03:39 AM
    I think connectors behave this way. Not sure what else it might be.
    May 15, 2018
    2
    05:39 AM
    hmmm, thanks for the suggestion, I hadn't considered that before. I'll check into that as a possibility once I'm back in the office on Monday.
  1. Setting Revit Parameter by "Phase Created"
    By bteskey in forum Dynamo BIM
    Last Post: January 29th, 2018, 02:26 PM
  2. Spot Elevation/ Level with both "project base point" and "survey point" 2017
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: November 28th, 2017, 04:43 PM
  3. Replies: 4
    Last Post: June 7th, 2016, 01:32 PM
  4. Error Message: "None of the created elements are visible in Floor Plan"
    By efficiencydesign in forum Architecture and General Revit Questions
    Last Post: March 8th, 2014, 07:05 AM
  5. Created sloped wall using "in place mass" and want to add window
    By nsoufiani in forum Architecture and General Revit Questions
    Last Post: December 7th, 2012, 09:11 PM
