Results 1 to 1 of 1
Thread: Repeated Family not perpendicular
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    689
    01:37 AM
    Hi all,
    I am having issues with an adaptive component not being perpendicular to the path it is following. Here is my workflow:
    1) I have created an adaptive component family, in this case a blade to act as screening around a car park curved ramp.
    2) Loaded this into the project.
    3) Created an In Place Mass and placed points along the path i wanted
    4) Created a spline with points and use the "Divide Path" function, which worked well.
    5) Create an instance of the adaptive family on the first divide point of the path
    6) Use the Repeat command, which it does.
    What i did notice however is the family does not stay perpendicular to the path it is following, which i need it to do.
    In the adaptive component family i have tried all of the "orients to" options in the adaptive family. Can anyone tell me why this is happening and / or how to keep the family perpendicular to the path ?
    Attached Thumbnails Attached Thumbnails Repeated Family not perpendicular-orients-.jpg   Repeated Family not perpendicular-not-perp.jpg
  1. Best practice for many thousands of repeated elements?
    By PatrickGSR94 in forum Architecture and General Revit Questions
    Last Post: April 25th, 2018, 05:04 PM
  2. Replies: 5
    Last Post: September 26th, 2016, 03:01 PM
  3. Repeated corrupt file!!!
    By id211 in forum Architecture and General Revit Questions
    Last Post: April 1st, 2016, 08:54 PM
  4. Replies: 0
    Last Post: December 17th, 2013, 10:45 PM
  5. Repeated Window Schedules
    By wcbii in forum Architecture and General Revit Questions
    Last Post: July 25th, 2011, 09:57 PM
