Results 1 to 3 of 3
Thread: Extra references in family
    February 28, 2017
    35
    03:44 AM
    When adding dimensions to the attached family there are a lot of references which Revit tries to snap to (both vertically and horizontally) and I'm unsure where those are all coming from? I'd like one reference plane at the centerline of the toilet land thats it, but can't even see where the "phontom" references are coming from. Any guidance would be greatly appreciated.
    Thanks,
    Attached Files Attached Files
    Gold Coast
    2,619
    06:44 PM
    Hit vv on your keyboard, go to annotations tab and turn on automatic sketch dimensions.
    Depending on the complexity of your family you may be surprised how many dimensions show up. These are the automagic ways Revit tries to help you. I wish they didn't exist as I'd prefer to control everything from scratch, but they do because Revit. You'll need to override them all to get total control.
    PS. You might also want to learn the different behaviours of reference planes in families. ie. strong, weak, not a reference etc...
    February 28, 2017
    35
    03:44 AM
    Thanks for the quick reply Elton! I was able to dig through and re-associate the temp dimensions so that I could delete all of those but Revit still tries to snap to these "phantom" references. It appears, when in the family editor, that those references are a product of the nested wall mounted flush valve family (when hovering a dimension command over the references the tip box says they are part of the wall mount flush valve family). Even when I delete the nested wall mounted flush valve family out of the host those references are still able to be selected and dimensioned to..? What am I missing? Thanks again
  1. Extra dialog
    By DaveP in forum Architecture and General Revit Questions
    Last Post: July 18th, 2017, 07:36 PM
  2. Building Coder: API Access to Family Instance References
    Last Post: May 17th, 2017, 08:15 AM
  3. Extra Window
    Last Post: December 7th, 2016, 05:30 PM
  4. View Reference Family: Leader and "extra text"?
    By doni49 in forum Architecture - Family Creation
    Last Post: October 23rd, 2015, 03:24 PM
  5. Extra line showing up on Window family...help??
    By darryl in forum Architecture - Family Creation
    Last Post: July 6th, 2011, 02:47 PM
Tags for this Thread
