Results 1 to 4 of 4
Like Tree5Likes
  • 3 Post By Twiceroadsfool
  • 1 Post By DavidLarson
Thread: Arrays in families
    July 10, 2015
    Boise, Idaho
    641
    10:34 AM
    Arrays in families
    Is there a way to have an array in a family have only one instance? Say I have a bunch of equipment that I want to have arrayed. The configuration may be as short as a single instance going up to dozens of them. I need them to be able to report the count.
    I have no problem as long as there are at least two in the array. But I need it to be able to be a single instance. This is due to another array that will start immediately after the first array. The equipment typically is one or two of 'A' followed by many 'B'.
    10,036
    11:34 AM
    Yes and No.
    Parameter: COUNT: Integer : Formula: Length / 6"
    Parameter: CountAct: Integer : Formula: if(COUNT > 1, COUNT, 2)
    Parameter: ArrayVis: Y/N: Formula: COUNT > 1
    Parameter: SingleVis: Y/N: Formula: not(ArrayVis)
    Then you have the array, and you ALSO have a single instance sitting there (not part of the array). Single instance visibility controlled by SingleVis. Array Item Visibility controlled by ArrayVis.
    EDIT: Forgot to mention, CountAct has to be the one ASSIGNED to the Array, even though COUNT is the one doing the math.
    EDIT EDIT: Changed the Formula for SingleVis. Makes more sense this way. Im overtired...
    Does exactly what you want with scheduling.
    July 10, 2015
    Boise, Idaho
    641
    10:34 AM
    Remind me to buy you a beer or three if you ever come to Boise. Thanks
    Twiceroadsfool likes this.
    July 10, 2015
    Boise, Idaho
    641
    10:34 AM
    Thanks for the update. It works with those parameters.
  1. Formula Help - Arrays & Visibility
    By cellophane in forum Architecture - Family Creation
    Last Post: September 20th, 2017, 04:12 PM
  2. Global Parameters & Arrays
    Last Post: June 2nd, 2016, 02:32 AM
  3. Replies: 0
    Last Post: March 12th, 2015, 05:45 AM
  4. Applying materials to arrays
    By cheinaranta in forum Architecture - Family Creation
    Last Post: April 19th, 2013, 11:06 AM
  5. How do you set up arrays less than 2
    By simon1688 in forum Architecture - Family Creation
    Last Post: December 16th, 2011, 05:04 PM
