Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree13Likes
Thread: What controls the view title line length?
    December 3, 2012
    Fernandina Beach, FL
    56
    06:00 AM
    In relation to dropping a view, what controls the length of the line? We don't like the line extending the full width of the view and find we are editing that for every view made. Nor do we like it left justified. I've not had any luck finding where this is directly controlled. Can you all guide me?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,037
    06:00 AM
    It is controlled by the extents of the view, although I don't know the technical specifics of what it references for the actual length. You can however constrain the title line to a reference plane in your family and control the length exactly. I have mine setup with several different sizes - 3",4",5",6" & 7" be default, but it's pretty easy to modify and add more if needed.
    Attached Files Attached Files
    biff likes this.
    December 3, 2012
    56
    06:00 AM
    Thank you Chad. Is there a default location relative to the view? I like that specifically sets the lengths. That eliminates all the different looks...much cleaner. IDK why didn't come up with that.
    cellophane likes this.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,477
    03:00 AM
    Quote Originally Posted by stevenpapke View Post
    cleaner? don't use the stupid line
    GMcDowellJr likes this.
    December 21, 2010
    Phoenix, AZ
    2,475
    04:00 AM
    Quote Originally Posted by Dave Jones View Post
    Amen, brother!
    lawrenceolmos likes this.
    June 21, 2012
    Tours, France
    880
    12:00 PM
    Agreed , We are not using that Stupid line anymore! lol
    December 3, 2012
    56
    06:00 AM
    Post up a sample image, love to throw darts. Has anyone figured out how the software justifies the location of the view title? I understand, its the view of the view. Its left justified, I get that. When we have a long section or long elevation, the standard in this office is not to run the line the full width, but to move the view title to the center and shorten the length. Removed or not, the line....IDC...trying to understand if this is hard wired in the software or controllable by default.
    Dave Jones's Avatar
    4,477
    03:00 AM
    The line has nothing to do with the justification. View titles are justified to the bottom left of the view. The line, if you use it, follows the view title. I don’t like lower left justification so I move each title to the bottom center of what’s in the view. And I haven’t used the line in some years as it was always a PITA to get it where I wanted it and the correct (to me) length, as you have pointed out
    Sent from my iPad using Tapatalk
    June 21, 2012
    Tours, France
    880
    12:00 PM
    ..... it was always a PITA to get it where I wanted it and the correct
    And don't forget about a rotated detail or view!! that's why we are not using that anymore!
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    281
    05:00 AM
    Another options is to uncheck Show Extension Line in the Viewports Type properties and underline the text in the View Title's label. Add spaces in the label's Prefix as desired to push the text away from the #. If you would like the line to extend past the text a bit add spaces with an empty Alt+Code at the end in the label's Suffix.
    The line will auto adjust to the text and no more fiddling with that PITA.
  1. View Title - line length
    Last Post: August 8th, 2017, 04:28 PM
  2. view title in one line
    By philsogood in forum Architecture and General Revit Questions
    Last Post: May 29th, 2017, 10:42 AM
  3. Replies: 3
    Last Post: September 14th, 2015, 07:32 AM
  4. View Vort or View Title Extension line
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2013, 02:23 PM
  5. How to adjust the starting location of the line in the View Title
    By narlee in forum Architecture and General Revit Questions
    Last Post: April 27th, 2012, 08:39 PM
