Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Twiceroadsfool
Thread: Transfer family parameters
    August 23, 2017
    10
    04:11 AM
    I am looking for a way to transfer a set of parameters from 1 family to another. A bit like transfer project standards, but then with family parameters.
    I came along a couple of interesting threads, but none of them seem to provide a solution:
    Parameter Jerk:
    https://forums.autodesk.com/t5/revit...r/td-p/4346844
    However, the latest release is for 2014. Does not work on 2018.
    Shared Parameter Converter:
    https://forums.autodesk.com/t5/revit...t/td-p/6964938
    However, user quote: "It appears the shared parameters converter has been removed by AutoDesk on purpose."
    So, I was wondering: Do you guys have a way of doing this?
    THanks in advance for your help!
    JN
    August 23, 2017
    10
    04:11 AM
    Did some more googling. found this:
    https://apps.autodesk.com/RVT/en/Det...autostart=true
    Seems to be what i am looking for.
    August 23, 2017
    10
    04:11 AM
    After a bit of testing:
    Looks promising, but it only lets me transfer Type parameters, not Instances.
    Furthermore, shared parameters are transfered as family parameters.
    If you have any further advice, please.
    10,036
    09:11 PM
    CTC Family Processor works on all types of parameters.
    Aaron Maller
    Director
    Parallax Team, Inc.
    jnoordzij and cganiere like this.
    January 19, 2012
    322
    09:11 PM
    I'd go with CTC's tool, but I did see a "free" app in the Autodesk App Store that could do it for free if the budget is tight. It was last night & after reviewing official Revit 2019 stuff I was too tired & loaded with other info to be able to retain the name of that app.
    Basically it will take specified parameters in a family & load them into other families.
    June 8, 2018
    1
    10:11 PM
    Just load the family with the parameters on to one without them. Then delete the inserted family parts. The wanted parameters will stay in both families
    Quote Originally Posted by cftrevizo View Post
  1. Replies: 0
    Last Post: December 15th, 2017, 04:45 AM
  2. 2015 Family Upgrader (revised)- Transfer Project Standard, Order Parameters, etc.
    By Twiceroadsfool in forum Architecture - Family Creation
    Last Post: May 9th, 2014, 09:26 PM
  3. Replies: 0
    Last Post: August 15th, 2013, 12:15 AM
  4. Replies: 0
    Last Post: July 31st, 2012, 11:45 PM
  5. Replies: 0
    Last Post: March 16th, 2012, 04:45 AM
