Results 1 to 8 of 8
Thread: Door Families not obeying the show in plan when cut check box
    December 20, 2010
    1,058
    01:35 PM
    Shouldn't sweeps(door frames) show in plan if they are set to off in plan view, but show when cut? Ie if I have an archtop frame and don't want to see the arch, i just want to see the frame cut thru, in the past I though I just unchecked the show in plan view and left the show when cut checked. However it doesn't seem to work, I can either have it on or off. Any thoughts?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,144
    01:35 PM
    Seems OK here. What version of Revit are you using?
    edit: quick mockup enclosed. I just slapped some crap together for concept, but it seems OK.
    Attached Files Attached Files
    December 20, 2010
    1,058
    01:35 PM
    2018.2
    Note I think the issue is that our door families are set up with Nested frame families.
    December 20, 2010
    1,058
    01:35 PM
    Yours work just as expected. If you don't mind, try nesting the same shape in and see if it fails.
    August 9, 2011
    Louisville, KY
    6,144
    01:35 PM
    Good point. Are the frames also shared? It looks like Nested families display oddly, shared & nested families work as expected, at least in the 30 seconds of stabbing at it that I did.
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    465
    06:35 PM
    Hi Scott, what family type are your nested frames out of curiosity?
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    11:35 AM
    What kind of hosting does your door frame use? I still get thrown off with face-based families on occasion, because what I often expect to be plan view is actually front/rear and vice versa. Uploading your family would be the easiest way for us to trouble-shoot it.
    10,200
    12:35 PM
    Mine are shared nested wall hosted Door Category frames, and it cannot be one monolithic piece or it is all or nothing in Plan.
    But that's fine with me, since I want the too and sides to be separate shapes (even for arches).
    I can't say for sure that Scott's firm still uses my old doors, but if they do, they are shared nested wall hosted Door Categories as well. They will need the sweep to not be continuous or it won't work.
    Aaron Maller
    Director
    Parallax Team, Inc.
  1. Is it possible to check file sizes of families within a project
    By joewallace in forum Architecture and General Revit Questions
    Last Post: August 21st, 2017, 06:53 AM
  2. Replies: 0
    Last Post: June 3rd, 2015, 12:45 AM
  3. Families quality check
    By jbenoit44 in forum Architecture - Family Creation
    Last Post: December 20th, 2012, 08:39 PM
  4. My Door Frames don't Show
    Last Post: May 15th, 2012, 12:52 AM
  5. Creating Door, Windoe and Door-cum-Window schedules floor plan wise
    By rohini in forum Architecture and General Revit Questions
    Last Post: October 6th, 2011, 01:47 PM
