Results 1 to 4 of 4
Thread: Filed Region GA Family Blocking Label on Sheet.
    Member ScubaMan's Avatar
    July 6, 2015
    199
    10:50 AM
    Hello all,
    I am trying to add a filled region behind some text in a sheet family. I want to be able to change the color (Green, Yellow, Red, and Blank). I created a GA Family and placed it behind the label. Got everything to look good in the family but when loaded into the project the filled region is on top of the label and you cannot see the text.
    I looked around and only found the following link. It did not work though. Anyone know of a better way to do this?
    Filled Region Blocking your Lines in a Project Title Block? - The Revit Clinic
    Thanks for the help,
    Steven
    10,200
    12:50 PM
    Can you show us what you are actually trying to accomplish?
    Member ecraider's Avatar
    May 19, 2014
    Concord, CA
    87
    05:50 PM
    This should do the trick.
    Try using this family.....
    Just nest it into your TB.... See pdf for instructions on parameters.
    Attached Files Attached Files
    July 6, 2015
    199
    10:50 AM
    Yes sorry. I have changed the design so the GA family is no longer behind the text but I would still like to know how this is suppose to be done. If you do not have time thats ok since I no longer need it at the moment.
    On the left is the family and the right is loaded into the project. In image two you can see that the text is behind the filled region.
    Thanks for any help,
    Steven
    Attached Thumbnails Attached Thumbnails Filed Region GA Family Blocking Label on Sheet.-capture.png   Filed Region GA Family Blocking Label on Sheet.-capture2.png
  1. Sheet Label Parameter
    By andyrh1982 in forum Architecture and General Revit Questions
    Last Post: May 26th, 2017, 05:00 PM
  2. Sheet Name Label Problem
    By domsib in forum Architecture and General Revit Questions
    Last Post: March 28th, 2013, 04:47 PM
  3. Sheet - Created my own label (problem)
    Last Post: November 22nd, 2012, 04:33 PM
  4. How to add a label under imported image (in sheet)
    By gpktm in forum Architecture and General Revit Questions
    Last Post: November 14th, 2012, 12:20 PM
  5. Replies: 0
    Last Post: August 17th, 2011, 10:20 AM
