Results 1 to 6 of 6
Thread: locker family not associating with host room (2017)
    June 26, 2014
    87
    11:06 AM
    i have a locker family and i would like to create a schedule that shows the lockers that are in each locker room (mens & womens.) i have created a furniture schedule and included these fields; room name, room number, family and type, mark, count, type mark. when the schedule is created the columns for room name & room number are blank. it seems as though my lockers are not associating with the room that they are located in. i have moved the room calculation point so that it is not on the ground plane and not in the center of the locker family and still no luck. i was hoping someone has a solution?
    i am attaching the locker family for your review.
    Attached Files Attached Files
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    465
    07:06 PM
    Seems to work fine for me
    June 26, 2014
    87
    11:06 AM
    so i copied the rooms with the lockers into a new project and created a schedule and it seemed to work in the new file. so there is something wrong with my project file.
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    650
    06:06 AM
    Are the lockers on the same phase as the rooms? (both are phase dependent)
    June 26, 2014
    87
    11:06 AM
    yes they are in the same phase. I found out that I had to move the "room calculation point" in the locker family.
    December 13, 2010
    650
    06:06 AM
    Ah - good catch. You probably dont actually need a room calculation point in there at all..
  1. change room's host level
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: March 7th, 2018, 04:11 PM
  2. Linked Room Tags Overlapping Host Model Items
    By lizbrack in forum Architecture and General Revit Questions
    Last Post: May 10th, 2017, 08:04 PM
  3. Bug when associating parameters of shared nested family
    By ekkonap in forum Architecture and General Revit Questions
    Last Post: May 5th, 2017, 11:43 AM
  4. Replies: 0
    Last Post: April 5th, 2017, 11:15 PM
  5. Replies: 1
    Last Post: September 30th, 2016, 03:33 PM
