Results 1 to 10 of 10
Like Tree4Likes
  • 1 Post By Geert
  • 1 Post By Andres Franco
  • 1 Post By sdbrownaia
Thread: Solid railing on a curved stair
    February 19, 2018
    3
    02:10 PM
    Hi all,
    I've got a problem with a solid railing i'm trying to apply to my curved stair. I have crated a simple rectangular profile and set it as the "Rail structure Non-continuous".
    It works fine-ish when I turn the connectors off
    But when i switch the tangent joins to "Extend rails to meet" it goes a bit crazy and curves into the stair.
    And this is what happens when i edit the railing path and change the slope from "by host" to "sloped".
    I run out of ideas by now of what might be causing this issue.. I have attached the railing profile and the plan of the staircase.
    Any help will be greatly appreciated.
    Attached Thumbnails Attached Thumbnails Solid railing on a curved stair-0.png   Solid railing on a curved stair-1.png   Solid railing on a curved stair-2.png   Solid railing on a curved stair-3.png   Solid railing on a curved stair-4.png
    Attached Files Attached Files
    Member Geert's Avatar
    February 8, 2011
    Les Vigneaux, Hautes Alpes, France
    141
    04:10 PM
    In cases like this I tend to use a wall with an edited profile
    cganiere likes this.
    February 19, 2018
    3
    02:10 PM
    Is there no way to make it work as an actual railing?
    I don't want to put walls where they don't belong as it will show up in a schedule (and if there are more instances of "wall railings" then creating filters for every single one will be a pain - about 15 people are working on this project).
    Thanks
    June 21, 2012
    Tours, France
    937
    04:10 PM
    Quote Originally Posted by Geert View Post
    yes, totally agree, and maybe an in place railing family will be more easy to model!, regards
    Member duende123's Avatar
    November 20, 2015
    186
    10:10 AM
    But ...... Can you edit the profile on a curved wall?
    June 21, 2012
    Tours, France
    937
    04:10 PM
    Quote Originally Posted by duende123 View Post
    Is not possible to edit a curved wall profile, but you can cut it with an in place wall void
    Attached Thumbnails Attached Thumbnails Solid railing on a curved stair-void.jpg
    December 20, 2010
    1,045
    10:10 AM
    you can use the railing tool, you just have to tell the segments to slope and give a custom height instead of letting it decide what to do.Solid railing on a curved stair-sloped-rail.png
    However this will only work if you want a parallel piece of glass, if you want the bottom flat and the top sloped you will need to use a swept blend at the landing or a wall with its top attached to a sloped ref. plane that connects the two or as the previous poster said a void.
    Andres Franco likes this.
    June 21, 2012
    Tours, France
    937
    04:10 PM
    Quote Originally Posted by sdbrownaia View Post
    Another workaround for this is to model several segments for the railing instead an unique model , various railings have the advantage to let more control, and as mentioned before it can be a combination of in place families and other techniques, regards
    February 19, 2018
    3
    02:10 PM
    thank you all!
    June 21, 2012
    Tours, France
    937
    04:10 PM
    Quote Originally Posted by gosiam View Post
    thank you all!
    If you find this useful please add it to Users reputation (See Image)
    Attached Thumbnails Attached Thumbnails Solid railing on a curved stair-useer.jpg
    kingjosiah likes this.
  1. Custom Railing for Curved Stair
    By Warp Drive in forum Architecture and General Revit Questions
    Last Post: January 12th, 2017, 04:35 AM
  2. Stair Railing
    By robledojuan7 in forum Architecture and General Revit Questions
    Last Post: February 10th, 2016, 02:02 PM
  3. 3 Run Stair Railing
    By Grumple in forum Architecture and General Revit Questions
    Last Post: September 24th, 2015, 03:33 AM
  4. How i can close this gap of stair to make it solid ?
    Last Post: October 7th, 2011, 11:12 AM
  5. Custom Stair railing
    Last Post: July 25th, 2011, 11:02 PM
