Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Andres Franco
Thread: Parametric glass
    October 20, 2017
    9
    06:45 PM
    Parametric glass
    Hi to all,
    Im new in this and if some can help me.
    i made new parametric window and i need insert parametric glass from manufacturer to my window but i get stuck, so if someone can help me I will appreciate it a lot.
    June 21, 2012
    Tours, France
    985
    07:45 PM
    HI, do you want to make what with your parametric glass?, please try to be more specific, regards
    October 20, 2017
    9
    06:45 PM
    How to glass be a part of my window, in attach. are files window and glass,
    I mean to insert some how glass in my window and to be able change glass thickness and cavity thickness
    December 21, 2010
    C.LONDON
    4,382
    06:45 PM
    National Building Library?
    June 21, 2012
    Tours, France
    985
    07:45 PM
    Quote Originally Posted by neznani View Post
    I think the best way to do what you are trying to do is Model your own glass it can be a separate RFA or not, but you need to be the one that model your own things otherwise you'll find so many issues.
    To give you a response to your question: Go to > New >Family, look for a Generic model family(?); once then you need to model your glass by using extrusions or whatever the method you prefer for this, use reference planes and so on to give control for your dimensions (thickness and so on), then you need to give it some parameters, Glass thickness will be a dimension one, Once your glass has a Thickness and Height, you need to give it a material parameter, once finished you can load your glass into your window family and once the you need to re map the glass parameters into your window family. without having more info I think is all I can say, hope this help
    cganiere likes this.
    October 20, 2017
    9
    06:45 PM
    Thank you very much
  1. Glass Symbols on Glass Elevations
    By kamranmirza in forum Architecture and General Revit Questions
    Last Post: September 4th, 2018, 05:07 AM
  2. Gradient glass
    By leetecture in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2016, 05:19 AM
  3. Is Revit a Parametric Designing software Or simply a Parametric Drawing one?
    By smshiran in forum Architecture and General Revit Questions
    Last Post: November 18th, 2012, 10:48 AM
  4. U-value Glass
    By Camille in forum Architecture and General Revit Questions
    Last Post: October 14th, 2011, 08:53 PM
  5. 2D Transparent Glass
    By mark b in forum Architecture - Family Creation
    Last Post: December 15th, 2010, 07:15 PM
