Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree8Likes
Thread: Horizontal & Vertical Offsets
    February 12, 2018
    2
    08:58 AM
    Hi i'm new to all this so i don't know if i have the right thread... so if i do then i apologise! i need to horizontally offset some symbols that are place on top of each other so they appear next to each other on the floor plan. However when i try to offset them they move left and i need them to preferably move left or right. In the "Horizontal Plan Offset" I've tried entering a minus at the start to see if it will go the other way but as expected it didn't, has anybody got any idea how to fix this?
    Attached Thumbnails Attached Thumbnails Horizontal & Vertical Offsets-revit-snip.jpg
    December 21, 2010
    C.LONDON
    4,382
    09:58 AM
    Welcome to the forum Jack!
    Revit's not so fond on negative dimensional constraints, as you've discovered - but worry not, there's a "trick"...
    Define an offset input - in your case <Horizontal Plan Offset>, but tie/manipulate the elements using "controls", so that:
    <Horizontal Plan Offset> = O
    OL=if(O>0,O,0)
    OR=if(O<0,abs(O),0)
    pay special mind to the difference between Os and 0s... (if only we had Consolas instead of Courier)
    jackmitford likes this.
    February 12, 2018
    2
    08:58 AM
    thanks for replying! i'm not sure i'm following.. how do i manipulate the elements exactly?
    March 21, 2013
    Phoenix, AZ
    275
    01:58 AM
    In other words, since labeled dimensions can only "push" (positive values), you create a pair of them (controlled by an input value) - one to "push" left (when the input value is negative), and one to "push" right (when the input value is positive). You connect these to reference planes so that the 'negative' pushes off the 'positive'. It makes more sense once you see it - this example should clarify.
    Attached Files Attached Files
    cellophane likes this.
    December 21, 2010
    C.LONDON
    4,382
    09:58 AM
    Sorry, there is a bit more it, and it would help to see your family - but essentially your loaded symbolic elements would get locked to reference planes being controlled by OL and OR.
    Check this blog post out for pictures: Strategy for Negative Values in Family Parameters. Revit - dp Stuff
    cellersick, JWR and duende123 like this.
    April 12, 2011
    Chicago, IL
    523
    03:58 AM
    I use a simpler approach that seems to work pretty well. Create a reference plane on the negative side set to "not a reference" and then dimension and lock it at some value that you know the negative offset will not exceed. Then create another reference plane to host your geometry and a calculated parameter that adds the desired offset to the dimension of the first reference plane. This lets the offset value entered be negative, but makes sure the dimension stays positive. It's the dimension going negative that is causing the error, not the parameter.
    JWR likes this.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    03:58 AM
    snowy, I love you man, but I have to strongly disagree with your parameter naming.
    I would NEVER name a parameter "O", and I'm not sure Revit is even going to let you name one "OR".
    Reasons being:
    First all, there's an operator already named OR (as in AND, OR) and even if Revit doesn't get confused, I would it I ever needed to edit your family.
    Second, I do not like short parameter names. Again, if anyone ever needs to edit the family, it's going to take them a lot longer to figure out what "O", or "OL" means than "Offset" or "OffsetLeft".
    Third, what happens when you later need to add an "Occupant Load" parameter? Can't use "OL" again.
    In summary, longer, more descriptive names have zero downside (except maybe more typing), and they make it a lot easier to understand and update things in the future.
    December 21, 2010
    C.LONDON
    4,382
    09:58 AM
    awww!
    (in my defence) t'was short-hand for the concept, not the finished formula.
    But I am guilty (?) of using a lot of short-hand for non-shared, family controlling, 'rig' parameters.
    Bite me.
    January 10, 2011
    St Paul, MN
    2,980
    03:58 AM
    Bite me.
    Sorry. Don't love you quite that much.
    Since jack said he was new to all this, I just didn't want him to start off with bad habits.
    Plenty of time to develop those once you know what you're doing!
    snowyweston and JWR like this.
    February 20, 2018
    Florida
    3
    03:58 AM
    I'm sorry but I have am trying these methods and I cannot get my light switch to work, please help.
  1. scheduling curtainwall vertical and horizontal mullions
    By Anondrafter in forum Architecture and General Revit Questions
    Last Post: June 28th, 2017, 02:15 AM
  2. Horizontal - Vertical Louvers Curtain System
    By KumarKapadia in forum Architecture and General Revit Questions
    Last Post: April 25th, 2017, 11:32 AM
  3. Horizontal - Vertical Louvers Curtain System
    Last Post: April 2nd, 2017, 04:52 AM
  4. Mullions: Horizontal and vertical 45° join
    By kosmos3d in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2016, 05:48 PM
