Results 1 to 5 of 5
Thread: Parametric family
    May 27, 2015
    11
    05:03 PM
    Parametric family
    Hello to all,
    Can anyone help me to figure it out why when change the type name of the road from 4 m into one with type name 4m to 6m and from 4m to 6m to 4 m does not work properly. The road should move exactly like the reference planes. The only situation when that road work just like I want is when I change the type name from 4m into one of 6 m. In the attachment I inserted the Revit 2017 file.
    Thank you in advance for your support.
    Attached Files Attached Files
    Last edited by Demeter; February 8th, 2018 at 12:13 PM. Reason: add new attachment
    December 21, 2010
    C.LONDON
    4,353
    06:03 PM
    Quite a few things to go through - but you want to:
    1. lock the centre of the sweep's arc
    2. lock the centre of the corner-bank element (?) arc
    3. reconsider which ref.plane sets up your origin (I would pick the arc centre)
    4. remove the 6000 dim to right (above the <Lengthe_2> constraint
    5. define & constrain a "helper" parameter for inner-radius
    6. accept that you can not have differing width's for a sweep (You need to use a swept-blend for that)
    EDIT#1
    EDIT#2
    Generally speaking though, it's your cambered profile, and desire to shape/flare between two widths that are setting the challenge - not the family rigging. Namely, rather than sketched-profiles, you would be advised to define a profile family so that you can articulate the (road) width and camber - and help counter the issues you'll have accommodating the blend.
    NB: you might want to look at using an Adaptive Component to do this.
    Additional thought: unless these are going to repeating precast modules, ala Scaletrix, then you're probably best off making the lengthes (sic) instance based.
    May 27, 2015
    11
    05:03 PM
    Hi, ok, thank you for your feedback, but my desire is to able tho change the with of the road not the length. The second attachment - exercitiu is made with swept blend but when I change one with from 4 to 6m and th other one stays at 6m or in the other case to 4 m the problem what I encounter is on radius, which is not tangent to the the center. Can you help me with that issue, maybe you can be able to put a revit file with that situation?
    December 21, 2010
    C.LONDON
    4,353
    06:03 PM
    The "issue" with the radius is (please forgive my explaining the obvious) that a radius is, by definition, a constant of an arc - so the challenge presented here is that the arc's centre point will "shift" the centre point, and angular size, to accommodate the variable widths of road - even with a 90degree turn.
    You could potentially change the circular-arc to an elliptical-arc, but since this is a road, and roads have their own rules for turns, I don't think applying base geometric rules is really going to return a "correct" result.
    May 27, 2015
    11
    05:03 PM
    Thank you snowyweston.
  1. Family Array Parametric Basics
    By williamcm in forum Architecture - Family Creation
    Last Post: May 19th, 2017, 09:18 PM
  2. Issue Parametric door family
    By selimcelem in forum Architecture - Family Creation
    Last Post: May 5th, 2017, 04:47 AM
  3. Parametric 2d family with materials
    By C.WILSON20 in forum Architecture - Family Creation
    Last Post: November 20th, 2013, 05:32 PM
  4. Parametric Family Problem
    By Fenners in forum MEP - Family Creation
    Last Post: September 12th, 2012, 07:47 AM
