Results 1 to 6 of 6
Like Tree6Likes
  • 1 Post By jmk
  • 2 Post By elton williams
  • 1 Post By jmk
  • 1 Post By cftrevizo
  • 1 Post By snowyweston
Thread: Unit Area in the Titleblock
    September 6, 2016
    Melbourne
    4
    01:22 PM
    Hi All,
    I don't know if someone else has asked this question before.
    Is there a way to show automatically the area of a unit in the title-block?
    When I do the marketing plan for one specific unit I would like to drag the view (of that unit) in the sheet and show its area in the title-block.
    I thought I could add an area schedule to the title-block but Revit doesn't allow to do that.
    Has someone tried anything else before? Any solution?
    Thank you all in advance for your help.
    Marco
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    08:22 PM
    Nativity? No. How areas and units are defined varies from firm to firm.
    If you do it enough and your method is consistent you could write a dynamo script that fetches the area and writes it to a sheet parameter.
    marco87 likes this.
    Gold Coast
    2,602
    12:22 PM
    you can put a project schedule on the sheet and just filter for the unit/s required.
    marco87 and jmk like this.
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,415
    08:22 PM
    Good point - I was focused on the "automatically" part of the request.
    marco87 likes this.
    January 19, 2012
    322
    09:22 PM
    ...Automation you mean, where the inputs are extrapolated. That's my BIM Nerdiness coming out, lol.
    So I remove wall bounding setting on all interior Unit walls. Then use a Massing family to "Label" my Unit Rooms (rooms within the Units) with Mass Tags that would track surface SF & WxH if desired, but only in the Documented (Typical) Unit Type & not done in every instance, which only the Room Element is. As for those Unit Sheets for Marketing/Presentation I would have a unique parameter to filter out the Unit content like Finishes/Doors/FFE onto "Unit" schedules. So the whole Unit would have the Room Element associated to it whole "Net" area. I would use an Area View Type if Gross SF'ages are needed/desired.
    marco87 likes this.
    December 21, 2010
    C.LONDON
    4,353
    03:22 AM
    Slippery slope... even with 2018's sorting of schedules, heavy filtering/isolation of schedules (IMO) can lead to exponential growth of labour - and whilst I understand the desire (to have such nuclear values reported on sheet, especially in the case of marketing plans) I still always push for such (schedule) data to be captured in a single output - that gets married back to the drawing by reference.
    marco87 likes this.
  1. Area Schedule - change Area Type
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: December 6th, 2017, 04:34 AM
  2. Titleblock help
    By mdomer in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2016, 03:56 PM
  3. Titleblock help
    Last Post: December 10th, 2015, 09:03 PM
  4. Building Coder: Mapping Display Unit Type to Unit Types
    Last Post: November 5th, 2013, 11:15 AM
