Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: Custom families - Importing CAD (3DM/SAT files) - Materials
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    465
    07:06 PM
    I've downloaded some manufacturer's RFA files for sanitaryware (as specified in the clients bathroom spec) but I soon found they were either faceted DWG imports or entirely modelled in Revit but of a shocking standard (non-symmetrical, overlapping edges etc..). I've started playing with Moment of Inspiration (Moi3D) as solution to making lightweight but good quality sanitaryware families. Its a great piece of software and I managed to mock up a concealed-cistern toilet pretty quickly from DWG views of the Plan/Front/Side. I then created a Generic Model, imported the file (using ACIS SAT) and found the object is entirely black. Changing the Generic Model material in object styles doesn't change the objects colour. I then tried using 3DM and found its a dark grey colour. Changing the OS material again has no effect. I did find that if I preassign the material to the GM catergory, the material does get applied. Is there something I'm missing? Can I also assign the imported mass to a custom object style (to avoid changing the material of all generic models in a project)?
    10,200
    01:06 PM
    Imported objects handle all of their materials By later, in the Imported Objects Object Styles.
    AND they perform horribly.
    December 11, 2013
    465
    07:06 PM
    Hey Aaron,
    I don't get anything listed in the imported objects within object styles, its entirely empty.
    If I load the family into a project and change the top level material for generic models, then the material changes just fine but I want avoid this category-wide assignment of a material to all GM.
    I've uploaded the model in its native 3dm format if anyone wants to test it out (had to put it in a zip file as the upload wont accept .3dm). Its still missing some fillets and a toilet seat but the geometry is extremely lean.
    Horribly in what way? All I hope for this and any other family created outwith the family editor is to just sit there and look pretty in a 3D view. If they can do that I'm happy as I will still use masked detail components for plan and elevation views.
    Attached Files Attached Files
    10,200
    01:06 PM
    Quote Originally Posted by BLothian View Post
    Hey Aaron,
    Hey, if your happy with it, awesome. Imported geometry is known to cause more fatal errors, more "error drawing the contents of this window," and more bizarre problems in general. I've seen a Revit model just refuse to print a furniture plan, over manufacturers stuff with imported geometry. :shrugs:
    Honestly, there's also nothing in that toilet that couldn't be modeled in Revit in ten minutes.
    But, back to the topic at hand: maybe 3dm stuff behaves differently than DWG, WRT materials and object styles. Even by later isn't really sustainable, to me.
    Aaron Maller
    Director
    Parallax Team, Inc.
    Member duende123's Avatar
    November 20, 2015
    186
    02:06 PM
    I don't see any way of assigning material.
    The most I could do is change your display with filters
    Attached Thumbnails Attached Thumbnails Custom families - Importing CAD (3DM/SAT files) - Materials-3dm.jpg
    January 19, 2012
    327
    01:06 PM
    Trust us! You're better off severed by taking the 10mins to rebuild the content. Good news is you could use the edged of the Imports as reference to build from or the copy over in a brand spanking new family from template for the sketching. Just verify the accuracy (angles/lengths) once you get rid of the imported geometry.
    January 19, 2012
    6
    08:06 PM
    to apply material parameter to Imported .SAT geometry,.. you will need to do the following:
    Revit 2016
    import your .SAT file
    Scale to suite
    Explode the .SAT file
    Select it (it's now native revit geometry)
    Apply material Parameter
    to apply another material,... create a material parameter, and assign a material to it
    then use the paint tool, and paint on your material parameter to surfaces you wish to have different material on.
    PS: the exploding of .SAT files only work with certain .SAT files
    (this workflow is no longer available for revit 2017.2 upwards)
    10,200
    01:06 PM
    Yeah, thats a terrible workflow. I dont advise that.
    GMcDowellJr likes this.
    July 10, 2015
    Boise, Idaho
    664
    12:06 PM
    that makes my eye twitch
  1. Importing and using Revit families from other files
    By kjubas in forum Architecture and General Revit Questions
    Last Post: October 14th, 2017, 07:22 PM
  2. Importing IFC files
    By paddy in forum Architecture and General Revit Questions
    Last Post: July 17th, 2014, 11:57 AM
  3. Importing .jt files in Revit
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: January 15th, 2014, 03:04 PM
  4. Importing Excel Files
    By Mr_Greg in forum Structure - General Questions
    Last Post: April 23rd, 2013, 08:59 PM
  5. Importing Materials
    By B Arch in forum Architecture - Family Creation
    Last Post: July 27th, 2011, 05:19 PM
