Results 1 to 5 of 5
Like Tree3Likes
  • 1 Post By snowyweston
  • 1 Post By anthonyB
  • 1 Post By Twiceroadsfool
Thread: Issues with the tool "Array"
    November 27, 2017
    Heidelberg, Germany
    17
    05:05 PM
    Hello Revit Community,
    I try to build a "complex" family which should be a flexibel "Shelf".
    Here an image what I did so far:
    So I would like to flex the following metrics:
    - width
    - height
    - depth
    - thickness
    - number (of shelf subjects horizontally and vertically)
    I did one big Extrusion and placed in it a Void Extrusion which I then made Arrays from.
    I was able to build that family, though after I built 2 Arrays (one horizontal, the other vertical), I wasn't anymore able to change the width and height, nor the thickness. All parameters changing the length got blocked. By blocked I mean I'll get this error message from Revit, when I try to change the parameter: "Constraints are not satisfied"
    I can't find another solution other than using Arrays, to build that Shelf with variable parameters. The problem with Arrays is, that they group up the Objects which the Array contains. And by grouping up Objects, I can't refer them outside of the group. Concluding to the issue of not being able anymore changing the parameter.
    Does that make sense? Sorry for my bad english (I'm not a native english speaker, if you don't know me so far)
    Does anyone got an idea for a easier solution building this Shelf flexible?
    Thanks for any help
    Sincerly your RevitNoob
    PS: I'm sure there is already such a complex Shelf family, I wanted to build it myself though. To learn more about creating families.
    Attached Thumbnails Attached Thumbnails Issues with the tool "Array"-kallax-regal-wei-__0243965_pe383236_s4.jpg   Issues with the tool "Array"-schuhregal.png
    December 21, 2010
    C.LONDON
    4,353
    03:05 PM
    Quote Originally Posted by revitnoob0815 View Post
    Great attitude!
    Now where to begin...?
    Well the first thing to know is Revit is a bit fussy about Arrays.
    In theory, and with some time, they work just as they're meant to - but there are some quirks.
    Firstly, when you "array" (polar or linear) the repeating elements (in your case the extrusion) becomes a group.
    The same lessons learned about Groups in a Project file apply to the family editor as well, insomuch:
    elements in groups do not like to be geometrically constrained.
    Well that's not entirely accurate;
    elements in groups don't mind being geometrically constrained so long as leave them "constrained" that way.
    but as soon as you attempt to adjust <Shelf Depth> or any other property, bad things happen. As you will have noted already. And this is not limited to sketched-constraints either; parametric-constraints complain just as much.
    So what to do?
    Well because you're on a voyage of discovery, it's not right to post up too many answers... so I will leave you with this one nugget, that is always applicable to arrays:
    Nested families.
    Too vague? Consider "dissolving" the exercise of design/constructing shelving. First you consider the overall dimensions, which then defines certain properties of the shelves, and then you define a pattern for the shelves.... if you compartmentalise the act (and constraints) of making/defining the shelf, you're free to only worry about the placement/repetition of the shelf.
    HTH
    cellophane likes this.
    Member duende123's Avatar
    November 20, 2015
    186
    10:05 AM
    Maybe you do not need to use nested families if instead of doing array of voids you do it with the horizontal element as Snowyweston recommends.
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    409
    12:05 AM
    My observation is the mantra: "Build it like they build it". I try to build my Revit models like the builder will build the building on-site. Same applies to families. Therefore I would not be using Voids but would instead use nested families for the shelves and inner vertical partitions, as snowyweston suggests. You will need to utilize Reference Planes plus linking up parameters for the nested families.
    10,036
    09:05 AM
    Definitely nested families, if you want to be able to change the number of shelves or supports in either direction.
    Aaron Maller
    Director
    Parallax Team, Inc.
    cganiere likes this.
  1. Revit 2016 features "Slant Wall Tool"
    By cliff collins in forum Architecture and General Revit Questions
    Last Post: January 25th, 2019, 03:48 PM
  2. Revit Server 2016 - Saving Issues "Not connected"
    By sdbrownaia in forum Worksharing, Revit Server & C4R
    Last Post: October 27th, 2016, 04:47 AM
  3. In Revit Architecture 2014, dont have "make adaptive" tool.
    By giovanni. in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 25th, 2014, 03:35 AM
  4. Rated "Linetype" Symbol Array Issues
    By brian.lee.scott in forum Architecture - Family Creation
    Last Post: August 29th, 2013, 10:14 PM
  5. "Show Hidden Lines" tool
    By ncebula in forum Architecture and General Revit Questions
    Last Post: February 24th, 2012, 11:07 PM
