Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By johanmattsson92
  • 1 Post By GMcDowellJr
Thread: Void Cutting a Nested Family in a Generic Model
    January 14, 2018
    Sweden
    5
    05:37 PM
    Hello there,
    I am working on a parametric portal frame that has a unique web. The web is corrugated and is a nested family because it uses an array parameter. Since the column and the rafter of the portal frame are tapered, the corrugated web (nested family) needs to be tapered aswell. But i can't seem to successfully create a void form to cut through the nested family.
    I've checked the forums here and have yet to find a solution to my problem. I've been using a nested face based void cut (cut with void when loaded checked) to try and solve the problem but it doesn't seem to want to cut the nested corrugated web i'm using.
    I'll attach my family here and maybe somebody can have a look (my issue will be more clear if you open the family and see for yourself).
    Note: The family itself is not finished so excuse me if it's messy
    Thanks and i look forward to a reply
    Attached Files Attached Files
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    411
    03:37 AM
    Good looking family. No need for apologies.
    Others may prove me wrong, but I don't believe you can get the void to cut those nested families as you desire.
    While I love making tricky families, I do always try to follow the KISS principal: Keep It Simple Stupid. Consider if you need that complexity in your family: In what views will you see that information? Will all that linework overpower your overall section/elevation views views? Would a filled region with hatching do? Will a detail in the project suffice?
    December 21, 2010
    Phoenix, AZ
    2,606
    10:37 AM
    A void can cut a model on the family, I believe, but it won’t in the project. You’ll need to put the void in the nested family and hook up it’s parameters to the host to control it.
    August 31, 2011
    Sydney, Australia
    411
    03:37 AM
    Quote Originally Posted by GMcDowellJr View Post
    Now there would be some good formulas.
    January 14, 2018
    Sweden
    5
    05:37 PM
    Hello,
    Thank you for taking your time to answer!
    The frame itself will be representing the actual frames we design at my company and will be used for renderings etc. Therefore a hatch wouldn't really do it in my opinion. But thanks for the tips.
    And i think i solved my own case this weekend. Instead of using it as a nested family i just created an extrusion directly in the generic model and arrayed it with the same parameters. And later i just put in a void and cut anything inside of the inner flanges. Worked out pretty ok.
    anthonyB likes this.
    December 21, 2010
    Phoenix, AZ
    2,606
    10:37 AM
    Quote Originally Posted by anthonyB View Post
    Now that I look at the family I can see why you'd say that. Array's are great... but they can't do what the OP wants. Best bet right now might be to use Dynamo to place and number each panel (from either end). That number could then be used to drive a formula to control the size of the cut. 2 things need to happen here -- you can't use the array since everything in an array needs to be the same, and you need some way of telling each panel where it is along the angle.
  1. Face Based Family with only a Void Nested into a Generic Model Family
    By Joshua Kohl in forum Architecture - Family Creation
    Last Post: October 18th, 2016, 02:12 PM
  2. Visibility Issue with Nested Generic Model in Door Family
    By billiam in forum Architecture - Family Creation
    Last Post: May 23rd, 2016, 08:48 PM
  3. Cutting Extrusion with a nested void
    By BLothian in forum Architecture and General Revit Questions
    Last Post: May 12th, 2015, 09:17 PM
  4. Void cutting nested families
    By dan_p87 in forum Architecture - Family Creation
    Last Post: October 18th, 2013, 04:10 PM
  5. Void issue with generic model
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: December 13th, 2011, 03:44 PM
