Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree4Likes
Thread: Need text that align/locks to ref planes to show in elevations
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    01:05 PM
    I'm building a "super cabinet" family that is made fairly exact to how cabinets are actually built. I have my adjustable shelf as a 3D extrusion inside the cabinet, and in the front elevation I have dashed symbolic lines aligned/locked to the shelf model geometry. The model geometry and symbolic lines are all tied to a Yes/No parameter to control whether or not the cabinet has a shelf inside. Works great in a project.
    However I also need the text "ADJ." just above those dashed symbolic lines that will show up in a casework elevation view. I need to be able to align/lock the text to ref planes so that it will adjust based on the shelf's position, and I also need the text to turn on/off following my Yes/No parameter for the shelf.
    Is any of this possible with anything other than model text? I really, really want to avoid model text if at all possible.
    December 21, 2010
    Phoenix, AZ
    2,606
    11:05 AM
    put the text inside a detail group along with a couple of invisible lines for alignment - you can align/lock the group
    duende123 and cganiere like this.
    July 7, 2017
    Hernando, MS
    492
    01:05 PM
    Thanks I'll give that a try.
    Gold Coast
    2,621
    04:05 AM
    Quote Originally Posted by PatrickGSR94 View Post
    What Greg says above is pretty much the only way to get it to work, unless you nest a label and align its ref planes.
    March 21, 2013
    Phoenix, AZ
    275
    11:05 AM
    The problem is that you want it in elevation. More discussion:
    https://www.revitforum.org/architect...tion-view.html
    You may have (limited) success using symbolic lines to draw your letters. They will not match other fonts. These are lines, not text, so will not scale with the view, and they do follow the mirroring, rotation, etc of the host family. If you choose to go this route, know that the old .shx fonts (in ACAD) are line-based and can be exploded within ACAD (TXTEXP).
    July 7, 2017
    Hernando, MS
    492
    01:05 PM
    hmmm it seems that grouping detail lines creates a MODEL group, while text exists in a DETAIL group. So doing that creates two separate groups.
    Also I can't control the visibility of the group with a parameter. I need it to be controlled by the Yes/No parameter that controls the shelf inside the cabinet, and its associated hidden lines in elevation.
    Mr. Revit OpEd
    2,882
    11:05 AM
    Text in elevation, in a family? Text in a family isn't visible when loaded in a project...it has to be a nested Label annotation family.
    cganiere likes this.
    July 7, 2017
    Hernando, MS
    492
    01:05 PM
    Quote Originally Posted by Steve_Stafford View Post
    But is there a way to make that work in the elevation view? If I can't make it work then I have to put a piece of dumb text on every cabinet section in all casework elevations for the adjustable shelf, which I really would rather avoid.
    Mr. Revit OpEd
    2,882
    11:05 AM
    ...But is there a way to make that work in the elevation view?...
    Sorry, I was focused on Text in a family not being visible in a Project.
    I think the advice to create the text with Lines is probably simplest. I'd be inclined to create a generic model face based family that you can place the model (or Symbolic) lines on and then host on the face of the shelf(ves), and/or offset from. Use Detail Level to avoid having the label appear in the majority of views.
    Controlling the visibility of the ADJ is the biggest justification of using tags...add them where required and you never worry about them anywhere else.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    348
    06:05 AM
    Yes you can!
    A fellow workmate of mine showed me this little trick
    although you can't assign a Visibility Parameter to the group itself, you can edit the group, then assign the visibility parameter to the elements inside the group
  1. Text limits that can align and lock
    By ecraider in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2016, 02:09 AM
  2. Elevations and “Show Hidden Lines: All”
    By jh75 in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2015, 09:19 PM
  3. How to show annotation text in a family and not model text
    By joewallace in forum Architecture and General Revit Questions
    Last Post: October 6th, 2014, 03:44 PM
  4. Masking regions, interior elevations, and locks?
    Last Post: May 8th, 2013, 06:57 PM
