Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By jmk
Thread: Cut a Nested Family (used to create an array) with a Void
    October 7, 2013
    10
    09:58 AM
    I apologize if this topic has been been addressed before, or if there's a definitive answer on the subject BUT....
    I'm creating a custom "Vented wood slat" family that has curved edges and will be many different sizes throughout the project. I would like to use a nested "slat" family, and then array it according to the size that will be eventually used. However, because of the curved edges on all four sides, I was thinking i would have a void, to cut that nested family, around the corners. Can I do this?
    I'm attaching a photo of what i'm trying to achieve.
    Thank you in advance!!!
    Attached Thumbnails Attached Thumbnails Cut a Nested Family (used to create an array) with a Void-vent-slat.jpg
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,425
    11:58 AM
    Are you arraying the curved edge slat family multiple times, or are you arraying the ridges to make the curved slat to get different sizes? Does the radius/size of the curved area vary?
    The first should be doable by arraying the element with the void (may need to do it in a second family). For the latter I don't think voids will cut an array, and if they do I suspect it would be unstable when the dimensions change. I'd try using 3 families - slat, nested into slat_array, nested into Vented Slat where it is cut by the void.
    October 7, 2013
    10
    09:58 AM
    I haven't tried nesting it a third time. I tried just nesting the single slat, array it, and then have a void cut the curved edges.
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,425
    11:58 AM
    Hmm - looks like you need a face based void family to cut loaded families. You will need the third family, since trying to cut the array in the family where it is arrayed gets the "changes to groups are only allowed in group edit mode error" So you'll need 4 families.
    slat>slat_array>Vented Slat
    face_void>Vented Slat
    Edit: here's a draft family (2017)
    Attached Files Attached Files
    cellersick likes this.
    October 7, 2013
    10
    09:58 AM
    i think this is EXACTLY what i needed. Can't thank you enough!!!!!! I've been racking my brain all day.
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,425
    11:58 AM
    You're welcome! It was an interesting puzzle because I was sure I'd seen it done before.
  1. Void to cut end off array of nested family - A metal deck roof sheet problem
    By williamturner1 in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2016, 05:20 PM
  2. Face Based Family with only a Void Nested into a Generic Model Family
    By Joshua Kohl in forum Architecture - Family Creation
    Last Post: October 18th, 2016, 02:12 PM
  3. How to create a Family with array of elements with different property values
    By i_nikolov in forum Structure - Family Creation
    Last Post: November 19th, 2015, 01:04 AM
  4. Angled array nested into roof truss family
    By gioginnelli in forum Architecture - Family Creation
    Last Post: June 26th, 2014, 05:04 PM
  5. Array nested voids in a family
    By dzatto in forum Architecture - Family Creation
    Last Post: May 25th, 2012, 02:10 AM
