Results 1 to 3 of 3
Thread: Hidden lines showing in 3d view
    Junior Member Laggingbehind's Avatar
    November 23, 2017
    North Kent
    5
    08:43 AM
    Another newbie question.... I've created basically an upturned box 1.2mm thick. Near the top I have a inset panel which sits on the inside face of the material thickness. However when I zoom out I can see the line where this panel sits which is a bit of a pain as I dont want it visible. When you zoom in it disappears.... any suggestions would be welcome
    Attached Thumbnails Attached Thumbnails Hidden lines showing in 3d view-zoomed-.png   Hidden lines showing in 3d view-zoomed-out.png   Hidden lines showing in 3d view-view-form-underside.png
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    846
    06:43 PM
    It happens with face differences of a few mm.
    November 23, 2017
    North Kent
    5
    08:43 AM
    Thanks mate. will see how much I need to reduce the roof panel back until it dissappears
  1. Slab cut outs not showing as hidden lines
    By edmund in forum Architecture and General Revit Questions
    Last Post: May 27th, 2015, 07:36 AM
  2. Revit Hidden line/Solid view still showing wireframe
    By kranjerj in forum Architecture and General Revit Questions
    Last Post: February 25th, 2014, 02:23 AM
  3. Hidden line view. Hidden lines showing.
    By redmonki in forum Architecture and General Revit Questions
    Last Post: July 27th, 2013, 09:12 AM
  4. Hidden lines not showing on small plan views
    By edmund in forum Structure - General Questions
    Last Post: October 31st, 2012, 01:02 PM
  5. Piles not showing hidden lines through structural foundations
    Last Post: June 26th, 2012, 09:13 AM
