Results 1 to 2 of 2
Thread: How to assign the suitable IFC and gbXML options to a newly created family?
    November 5, 2016
    7
    03:47 AM
    Hello!
    For the purpose of Energy Analysis, I have created a new Window family, but I don't know how should I assign the correct IFC options or tag to correctly export my window.
    I also have the same question with respect to gbXML export of this window, however, I have some doubts because I think gbXML export should be easier and more automatic.
    I would appreciate any help!
    Thanks,
    Arghavan
    December 3, 2017
    3
    05:47 AM
    To export your revit object in appropriate ifc type. you need to check your IFC export settings. you can check by going to export, Options, IFC Options.
    hete you will find Revit Catagory column and IFC Class Name Column. If You see Not Exported in IFC Class name in front of your Desired Revit Catagory, You Can Assign appropriate IFC Class name there.
    Remember Your IFC Class Name should be supported by revit.
    check the following list to make sure that Revit supports the desired IFC classes.
    https://knowledge.autodesk.com/suppo...C90A9-htm.html
    Hope it helps you.
    Good Luck.
    Attached Thumbnails Attached Thumbnails How to assign the suitable IFC and gbXML options to a newly created family?-ifc-options.jpg
  1. Assign material libraries to a family
    By M_Schuster in forum Architecture - Family Creation
    Last Post: October 7th, 2016, 04:20 AM
  2. created a family but
    By nick_h in forum MEP - General
    Last Post: January 14th, 2014, 08:08 PM
  3. Replies: 0
    Last Post: September 4th, 2013, 10:15 AM
  4. Why are all my walls changing to my newly created wall?
    By vicky0188 in forum Structure - General Questions
    Last Post: November 23rd, 2012, 02:04 PM
  5. Replies: 0
    Last Post: November 28th, 2011, 12:16 AM
Tags for this Thread
