Results 1 to 2 of 2
Like Tree3Likes
  • 3 Post By Alex Page
Thread: how to rotate text label
    July 20, 2011
    850
    02:54 AM
    seems text label is very picky in terms of rotation w/ its locked "host" (ref line for instance), any particular reason and/or workaround?
    Attached Files Attached Files
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    649
    09:54 PM
    OK:
    1. Put in another refplane at 90 degreess to the original, put it at the end of the refline that you want to align the nested label to. (i.e. the beginning or the end) What needs to happen is that the text can "rotate" around that, so the text needs to be centred on its refplanes (as you have done)
    2. Now, the trick is (would you believe) when locking the 90 degree refline by dimension, you dimension from the nested label family to the 90 degree refline and then lock it :
    ( I tend to do this part before aligning to ensure its right)
    3. Once that is down, align the nested label familiy to the associated refplanes and lock them together (using standard methods)
    Your fixed family attached for your investigation
  1. View Title with Label with Text Parameter?
    By blusurfer in forum Architecture - Family Creation
    Last Post: November 6th, 2017, 09:12 PM
  2. Label text as Type parameter
    By cnd in forum Architecture - Family Creation
    Last Post: October 5th, 2017, 07:32 AM
  3. Rotating label text issues
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: January 26th, 2017, 03:39 PM
  4. Vertically wrap all text in a label?
    By kescr in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2014, 08:33 PM
  5. Title Label Text Size
    By Ant123 in forum Architecture and General Revit Questions
    Last Post: February 1st, 2013, 02:43 PM
