Results 1 to 8 of 8
Thread: Arc Layout Jig - Radial Array, Controlled By Arc Segment Distance
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    10:50 AM
    I'm trying to build a jig to layout mullions along an arc; am math stupid and subsequently lost. The two controls I'd like to have are the angle and arc segment distance, the latter taking precedence if needed.
    I've looked at the formula stuff Alfredo posted a while back on it but it all seems to require the arc height, which I don't really care about. I've also looked at the brick arch that Aaron posted and I still haven't figured that one out... Also found the old post David Baldacchino made and am stumbling through that but not quite there yet.
    All that said - can this all be controlled by the arc segment distance? If so - how?
    10,036
    09:50 AM
    Sure, it can. The *Revit constraint* might not be able to be an arc length, depending on what youre making (post it?).
    But if you have:
    Radius
    Angle of Overall Arc / Length of Overall Arc
    Number of segments
    Angle of segments
    All but one of them can be parametric. One has to be *informed* by the others.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    10:50 AM
    Looks like you want to just calculate a bunch of circle sectors (arc segment) along a larger sector (arc length). Perfectly easy to do. Are you arraying by last or by second?
    August 9, 2011
    Louisville, KY
    6,104
    10:50 AM
    Hopefully the sketch helps explain it. I started a family, got lost in all the nested-nested-nested-array stuff and didn't get much more than a circle so far... Also got pulled into something else altogether Per the doodle - I'm trying to get the jig to set AS to a relatively normal number (24", 36", 48", etc) and be able control the Radius. The angles don't really matter, and I don't really care if it is a quarter-circle, half-circle, or full circle - although a full circle would probably be the most useful long-term.
    One of these days I'm going to sign up for remedial math..
    Attached Thumbnails Attached Thumbnails Arc Layout Jig - Radial Array, Controlled By Arc Segment Distance-arrayjig.jpg
    December 21, 2010
    C.LONDON
    4,353
    03:50 PM
    Not exactly a rig for set out, but I've a natty CWP panel that I think might help you - I'll try to remember to fish it out tomorrow.
    10,036
    09:50 AM
    Both the Brick Arch Family and the Table and Chairs do all of this, but its a matter of picking which variables youre going to input, and which you arent. You keep using phrases like "relatively normal," and "i dont care if its this or that," which makes me think you havent fully decided which things are driving and which things are driven. How the constraints are done might depend on the answers to those questions.
    August 9, 2011
    Louisville, KY
    6,104
    10:50 AM
    Both the Brick Arch Family and the Table and Chairs do all of this, but its a matter of picking which variables you're going to input, and which you aren't. You keep using phrases like "relatively normal," and "i dont care if its this or that," which makes me think you haven't fully decided which things are driving and which things are driven. How the constraints are done might depend on the answers to those questions.
    I'll try and pull apart the arch & table some more tomorrow - I get lost in all the variables (algebra was not my forte; geometry though, aced it!)
    Current goal is to layout storefront along an arc, and I'm trying to get the panel sizes (arc segments) to clean numbers. I'm not as worried if it is 36-1/4" vs 36", I'm just trying to avoid 35-21/256" numbers (stupid imperial measurements), i.e. relatively normal numbers.
    I would very much prefer a full circle long-term, but there is no reason I can't just mirror one rig to make a circle.
    August 9, 2011
    Louisville, KY
    6,104
    10:50 AM
    I'm apparently missing something stupidly simple because I can't get the array to work with an angle parameter, regardless of if I use a family or just reference lines... Anyone mind looking at the attached video and pointing me in the right direction?
    https://www.screencast.com/t/OzJULXgFd
  1. Sections - Repeating Gap Segment Distance
    By damo3 in forum Architecture and General Revit Questions
    Last Post: November 24th, 2016, 11:05 PM
  2. Radial Distance Measurement Issue
    By detroitigerz in forum Architecture and General Revit Questions
    Last Post: September 5th, 2015, 07:37 PM
  3. Radial Array - Modify Distance Between Objects
    Last Post: May 12th, 2015, 04:50 PM
  4. Radial Array
    By CBukowski in forum Architecture and General Revit Questions
    Last Post: December 5th, 2012, 06:30 PM
  5. Radial array/offset by distance
    By thv in forum Architecture and General Revit Questions
    Last Post: November 15th, 2012, 09:43 PM
