Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By Robin Deurloo
Thread: Complex Smooth Chair Family
    October 14, 2017
    5
    08:17 PM
    Hii,
    I am going through a problem that i have to create a revit family of chair as attached image.
    chair is curved in both direction and edges are equally smooth.
    Can anybody suggest me the best process of creating this kind of family.
    Regards
    Kamal Chhetri
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:47 PM
    There is no image and chairs and furniture are a challenge.
    Post the image and we can give better advise.
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:47 PM
    You can do it in Revit with 2 extrusions, a void and a sweep and you get something like the right example on the image (selected it all so you see the separate parts) or you can put it trough Fusion 360 and get a smoother finish on it. Takes a bit more work, but looks pretty nice (that's the left example)
    cganiere likes this.
    October 14, 2017
    5
    08:17 PM
    Is simple extrusion sufficient or we have to go for massing...coz the shape is too much up and down.
    October 14, 2017
    5
    08:17 PM
    Can you send that revit family..before fusion and all..a nativ one..wana check once
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:47 PM
    Quote Originally Posted by kamal152 View Post
    It all depends on what you want to do with the family. If it is just for space planning an even simpler family will do, for Shaded views this one might be OK, but it has some extra vertices you keep seeing. For high end rendering you will probably have to go a different direction, either use Fusion to model it of get it from the web somewhere.
    Sure, I attached it for you.
    Attached Files Attached Files
  1. Cut a complex host family with a nested family?
    By Rex Wave in forum Architecture - Family Creation
    Last Post: July 24th, 2017, 01:03 PM
  2. Complex Family
    By Rhy5 b in forum Architecture - Family Creation
    Last Post: August 21st, 2014, 02:29 PM
  3. Complex roofplate family
    By Bross in forum Structure - Family Creation
    Last Post: May 23rd, 2013, 10:53 AM
  4. Share a chair family
    By kienviet in forum Architecture - Family Creation
    Last Post: May 31st, 2012, 01:11 PM
