Results 1 to 6 of 6
Thread: Rotate Material TAg
    Member jsnyder's Avatar
    December 9, 2010
    AUGI Refugee
    340
    07:02 PM
    Rotate Material Tag
    We have created a material tag that we use to tag floor finish transitions in plan views. I can easily control these with visibility parameters to switch them between left and right reading and also change them between vertical and horizontal orientation. I cannot, however figure out how to rotate them at an angle other than 0, 90, 180, 270.
    Apparently some types of tags (e.g. room tags) can have their orientation set to "model" and you can rotate them however you need.
    It possible to rotate material tags in a similar fashion?
    New Member Parametric Components's Avatar
    November 15, 2017
    Kansas City
    1
    08:02 PM
    HI::
    Select Material Tag >> underneath ribbon (upper left corner) you'll see a Dropdown 'Horizontal' >> change to 'Vertical'
    Best,
    PC
    PARAMETRIC COMPONENTS – Premiere Revit Content Developer
    December 9, 2010
    AUGI Refugee
    340
    07:02 PM
    Quote Originally Posted by Parametric Components View Post
    HI::
    Best,
    PC
    Thanks, PC, but that doesn't really answer my question. I know I can switch between horizontal and vertical reading tags. My question, and perhaps I was not entirely clear on this, is how to rotate a material tag to some other non-orthogonal angle like 63 degrees - or whatever angle I need.
    Welcome to the forum, BTW.
    Member duende123's Avatar
    November 20, 2015
    186
    10:02 PM
    Select the tag
    change to "model"
    and rotate the tag 63 degrees
    December 9, 2010
    AUGI Refugee
    340
    07:02 PM
    Quote Originally Posted by duende123 View Post
    Select the tag
    change to "model"
    Unfortunately, I do not see the "Model" option available when I select or insert a material tag. I only see Horizontal or Vertical.
    November 20, 2015
    186
    10:02 PM
    Sorry , I tried with a room tag.
    other tags only allow horizontal and vertical
    I do not know why
    and if the tag family has checked , Revit disallow this option
  1. rotate material on fascia (2015)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: November 25th, 2015, 12:33 AM
  2. Quantities or Material Takeoff, material costs and thermal values
    By alfakappa in forum Architecture - Family Creation
    Last Post: August 22nd, 2014, 10:34 AM
  3. Can't find site material (grass) in material list in Revit 2014
    By Tony Phillips in forum Architecture and General Revit Questions
    Last Post: August 29th, 2013, 04:01 AM
  4. To rotate sheets or to rotate views
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: April 19th, 2013, 03:19 AM
  5. Rotate a material in baluster panels
    Last Post: February 14th, 2011, 12:57 AM
