Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree2Likes
Thread: Perforated metal panels
    July 10, 2015
    Boise, Idaho
    538
    10:18 PM
    I have a project where we'd like to use perforated metal panels but whenever we try to model the perforations correctly the sheer number of holes bogs the project down. Normally I'd just use a material but no... this time having the holes so the shadows are rendered correctly is what's needed.
    Is there any particular trick to make this work better? Our panels are 2' x 18' with 1/2" holes every 1 1/2" o.c.
    What we'd really like is to use a material if there is a way to do it and get properly rendered shadows.
    Senior Member Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    879
    06:18 AM
    Do you want the holes just to be rendered, or should they be there in a shaded view as well?
    For renderings you can edit the material and add a cutout.
    One thing that might help, if you want the holes to show up all the time, is create a panel that has them just at the fine Detail Level and not at the coarse or medium Detail Level. This way they will not bother you most of the time when modeling in Medium.
    July 10, 2015
    Boise, Idaho
    538
    10:18 PM
    We want them to render correctly, cast shadows, etc. Once the client is properly impressed we're going to swap out the family for one that doesn't have the holes in it. Until then, we need them there
    August 19, 2011
    New Hampshire
    496
    12:18 AM
    What have you been doing previously? An array of holes, one big void extrusion modeling every hole?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,885
    12:18 AM
    Have you tried a divided surface?
    July 10, 2015
    Boise, Idaho
    538
    10:18 PM
    I've previously modeled it with every hole as part of the extrusion.
    9,459
    11:18 PM
    More on this in a bit. Jumping on a conference call...
    Attached Thumbnails Attached Thumbnails Perforated metal panels-2017-01-02_18-24-58-nested-voids.png
    December 21, 2010
    C.LONDON
    4,292
    05:18 AM
    Since this is viz. exercise I'd be inclined to push it out to another program.
    June 21, 2012
    Tours, France
    796
    06:18 AM
    You can do it by modeling as a window in lieu of model all the window components you just need to model you panel with the perforations, hth
    July 10, 2015
    Boise, Idaho
    538
    10:18 PM
    From the thumbnail should I assume nested voids work the best?
  1. Modeling extruded metal panels on wall
    By RipleyLlessur in forum Architecture - Family Creation
    Last Post: October 11th, 2016, 04:34 PM
  2. Kingspan Metal Panels
    By veuxx in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2015, 11:50 AM
  3. Huge help for a parametric perforated metal facade
    By giannifrullo in forum Architecture and General Revit Questions
    Last Post: June 10th, 2015, 09:31 PM
  4. Perforated walls
    By lallanji in forum Architecture - Family Creation
    Last Post: August 27th, 2014, 05:07 PM
  5. Perforated curtain wall panels
    Last Post: February 5th, 2013, 02:39 AM
