Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree1Likes
Thread: Shared annotations in a model family
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    393
    05:11 AM
    My Ceiling Light families contain a different Generic Annotation symbol each.
    To change or swap these I need to edit the appropriate family. I thought it would be an idea to make the annotations Shared so I could put them on a <Family Type> parameter. However it appears that Shared annotations cannot be loaded into another family.
    Are there any alternative approaches to allow swapping out of symbols from within the project environment?
    Thanking you.
    August 31, 2011
    Sydney, Australia
    393
    05:11 AM
    If I load my shared annotations directly into the project, then they are available in my <Family Type> parameter in the light fitting family, however they do not show.
    (The light fitting shows but not the shared annotation. Swap it back to the not-shared annotation and it is visible again.)
    As far as I can see my Visibility options are not affecting this.
    Gold Coast
    2,147
    04:11 AM
    Make sure the actual <family type> parameter is a shared parameter as well as the family being shared
    August 31, 2011
    Sydney, Australia
    393
    05:11 AM
    Thanks for the input. Interesting idea.
    Added a new Shared Parameter to our file; added it to the family; and associated the Generic Anno to this param. But the symbol still disappears when I swap out to it in the project environment. (And the unshared anno shows again when I change back to it.)
    Is this the method you use and it works?
    Gold Coast
    2,147
    04:11 AM
    Can you upload the family?
    October 14, 2011
    Boston, MA
    196
    01:11 PM
    this is not the tidiest solution but if those all those ceiling fans were separate families (not types within a single family), you could stack them on top of each other in the Ceiling Light Family and control their visibility by type
    or there may be a way to use that same visibility approach with a single generic annotation family with different types
    August 31, 2011
    Sydney, Australia
    393
    05:11 AM
    Thank you for the offer.
    Thanks also, billiam.
    Attached Files Attached Files
    Senior Member
    December 16, 2010
    702
    04:11 AM
    also just as an additional thing
    if it is a one off option (ie If Downlighting A, it can not be any of the other choices) then you can add a parameter to the formula section of each of those "downlight option" yes/no parameters of
    Downlight A = not (or(Downlight B, Downlight C, Downlight D, Downlight E, Downlight F))
    Downlight B = not (or(Downlight A, Downlight C, Downlight D, Downlight E, Downlight F))
    etc.
    This means when you toggle each option it will not allow the user to have multiple options toggled.
    I think this syntax is ok, might need to add in a new "or" conditional with a new bracket for each case but I think as shown should be ok.
    cganiere likes this.
    Member duende123's Avatar
    November 20, 2015
    150
    01:11 PM
    Quote Originally Posted by Karalon10 View Post
    downlight A = no (o (downlight B, downlight C, downlight D, downlight E, downlight F))
    downlight B = no (o (downlight A, downlight C, downlight D, downlight E , Downlight F))
    It seems to me that Revit is not going to accept these formulas
    Attached Thumbnails Attached Thumbnails Shared annotations in a model family-circ.jpg
    Senior Member
    December 16, 2010
    702
    04:11 AM
    did you copy the entire line in to the formula?
    You should not include the "donwlight A =" part at the start of the formula that I showed.
    just this part
    and put that in the Downlight A paramater formula box.
    If you include the first part of it you will get the circular chain of reference problem for sure.
  1. Moving family in elevation deletes annotations
    Last Post: March 9th, 2015, 02:23 PM
  2. Revit OpEd: Family Not Shared vs Shared
    Last Post: September 13th, 2013, 03:45 AM
  3. Linked file annotations appear above models and annotations in main model..
    By josephpeel in forum Architecture and General Revit Questions
    Last Post: May 15th, 2013, 01:41 PM
  4. Decrease text size in family editor? (for radius and other parametric annotations)
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 27th, 2013, 05:12 PM
  5. Live Session - Family Creation Series #4 | Family Phasing, Sweeps and Shared Params
    By rkitect in forum Architecture and General Revit Questions
    Last Post: May 11th, 2012, 06:24 PM
