Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree3Likes
Thread: Project Base Point and Suvey Point
  1. #11
    Gold Coast
    2,071
    07:46 PM
    Quote Originally Posted by biff View Post
    Looking at that building coder link, i see he is using snoop. Is that available during the initial install/setup in the bim tools part? Or part of developer kit?
    Revitlookup is an addin. From memory (?) it is part of the SDK ( at least it used to be), although you need to compile it yourself. If you google you can find installers for each revit release. It installs on the addin tab.
  2. #12
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    671
    08:46 PM
    thanks elton. Think it's a bit far down the rabbit hole for me..
  3. #13
    Gold Coast
    2,071
    07:46 PM
    Dont fret, I know almost nothing about coding or compiling. Although it's aimed at coders and developers I still get good value out of Revit lookup for things like finding cad (to delete) or view templates (copy to other projects) and other things. You'll find links to 2017 & 2018 installer versions here Revit Add-Ons: Free (and Compiled) Revit Lookup 2017. Give it a go!
  4. #14
    June 13, 2011
    Australia
    671
    08:46 PM
    Ohhhh, ok, ....... He said slowly, as he inched towards the edge and looked over..
    Dave Jones likes this.
  1. Adjust project base point vs survey point in elevation
    By iru69 in forum Architecture and General Revit Questions
    Last Post: October 10th, 2017, 11:15 PM
  2. Project Base Point | Survey Point | Absolute Elevation Issue
    By siqbal16 in forum Structure - General Questions
    Last Post: March 29th, 2016, 10:16 PM
  3. Replies: 0
    Last Post: October 23rd, 2015, 04:15 PM
  4. Replies: 0
    Last Post: August 10th, 2015, 12:15 PM
  5. Replies: 0
    Last Post: May 25th, 2015, 12:15 PM
