Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree8Likes
Thread: System Families
    January 19, 2012
    202
    06:41 AM
    Lightbulb System Families
    Wondering if anyone knows of a good site (or provide samples) to download lots of typical system families (mainly focused on the ceilings, floors, & roofs) no matter the layer sizes, but as long as it's composed correctly, & no matter the materials applied. As long as it's a "typical" condition in the great USofA. Wondering to see if the small collection I have is adequate for "typical" conditions to start out with, or more out there that I haven't encountered for whatever reason.
    Coeur d Alene, ID
    4,278
    04:41 AM
    Quote Originally Posted by cftrevizo View Post
    Check out Autodesk Seek....errr...I mean BimObject.com Download free Revit, ArchiCAD, SketchUp, Vectorworks and AutoCAD BIM objects | BIMobject
    9,070
    06:41 AM
    My current list of Partitions for "typical USA conditions" currently counts:
    58 interior partitions.
    26 exterior wall types.
    Keep in mind, the number of them is going to depend on things like: Do you do Insulation by wall type or instance, fire rating by wall type or instance, wall height by wall type or instance, and do you build partitions as entire assemblies with finishes, or finishes separately.
    My answers go:
    1. By instance
    2. By Instance
    3. By Instance
    4. Separately
    That means the counts of wall types above is just about the smallest number of partitions that account for Wood Framed, Metal Framed, CH Stud Framed (Shaft), CIP Concrete, and CMU Block walls out there, with a variety of sheathing conditions and separate finish walls.
    In the past, i have modified this system for customers that wanted (for instance) Fire Rating to be "By Type." Similarly, ive modified them to be Wall Height by type, and insulation by type. That made the SAME partitions counted above, amount to over 400 wall types.
    January 19, 2012
    202
    06:41 AM
    Attached is a sample of the source file I'm working on. I'll be using this file to then hook it up with my CTC BIM List app.
    Member cganiere's Avatar
    January 5, 2011
    Orange County, California, USA
    190
    04:41 AM
    Here is a site that lets you make the system families in a web browser interface.
    https://bimsmith.com/Home/Index
    9,070
    06:41 AM
    Yeah. Just be prepared to have 15 tons of manufacturers **** stuffed in to your models with any of the site like that. BIMObject, BIMSmith, whatever.
    Dave Jones and snowyweston like this.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,295
    04:41 AM
    LOL! agreed. JUST MAKE IT YOURSELF! It's not that hard and it makes you really cool with your Revit friends ;-P
    December 21, 2010
    Phoenix, AZ
    2,210
    04:41 AM
    [QUOTE=Twiceroadsfool;182609]
    Similarly, ive modified them to be Wall Height by type, and insulation by type. /QUOTE]
    How does that work? I mean I know how to do it, but there's nothing that would prevent the wall from being radically different than the type.
    9,070
    06:41 AM
    Correct. Whixh is why I think it's stupid. It's a user action to change an instance parameter, and a user interaction. To change a wall type. So I think it's completely pointless.
    Was entirely manual, and- imho- a waste. Even if you automated it somehow, I don't even see a point. No value added at all.
    December 21, 2010
    C.LONDON
    4,212
    12:41 PM
    Question:
    Do you have these (all) "prototyped" somewhere?
    I'm increasingly drawn toward a "twin template" workflow; with one "the real one", as in the actual .rte, pre-populated with "most common" conditions; and a second, "reference template" (actually a model, perhaps even a workshared one, potentially-always-linked into the aforementioned "real" template) where all these permutations, w/ all their complimentary views, inc. 3D cut-aways, are modelled - and "reference'able" (as a link) so not adding additional weight to the "active" (project) model.
  1. System Classification for Families,...
    By Abdelraouf Muhammad in forum MEP - General
    Last Post: September 25th, 2016, 09:30 AM
  2. escalator system families
    By andreas2 in forum Architecture - Family Creation
    Last Post: May 19th, 2016, 09:56 PM
  3. Data in Families (System & Component)
    By d.stairmand in forum Architecture and General Revit Questions
    Last Post: July 10th, 2014, 09:35 PM
  4. Profiles in system families
    Last Post: July 11th, 2012, 10:17 PM
