Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Like Tree8Likes
Thread: System Families
  1. #11
    8,347
    03:43 AM
    Yep. They are all in my template.
    I don't see ANY upside, or ANY benefit, to storing them outside the project and making people bring them in somehow. Whether you call it *container files,* *twin templates,* *Repositories* or something else, at the end of the day you are making someone go load things in that will be present in the majority of projects. They start out in my template, and i just tell folks to leave them there even if you don't need them. There's no harm in them sitting there.
    JWR and cganiere like this.
  2. #12
    January 19, 2012
    87
    03:43 AM
    The only reason I'm using "container/source/seed" file with BIM List is the new firm I'm managing is still mostly green to BIM. So to keep the Template as virgin & spiffy & cartooned as possible without having to continually open it to edit content much until the maturity level has increased. Also a temporary strategy to help with standardization & to adapt to their "graphic standards" at the same time, including material/fill region nomenclature. No doubt CTC's BIM Batch tool helps to re-path the other content when upgrading/updating, but since I'm having lots of hands wanting to touch the "jewels" that need to get "familiar" with "processes" in case I'm "not available/around" & not blow up the Template without my supervision.... ;p
  1. System Classification for Families,...
    By Abdelraouf Muhammad in forum MEP - General
    Last Post: September 25th, 2016, 09:30 AM
  2. escalator system families
    By andreas2 in forum Architecture - Family Creation
    Last Post: May 19th, 2016, 09:56 PM
  3. Data in Families (System & Component)
    By d.stairmand in forum Architecture and General Revit Questions
    Last Post: July 10th, 2014, 09:35 PM
  4. Profiles in system families
    Last Post: July 11th, 2012, 10:17 PM
