Donate Now Goal amount for this year: 3000 USD, Received: 2527 USD (84%)
Results 1 to 4 of 4
Thread: How to make lines visible over mask or filled region?
    January 27, 2016
    7
    11:57 AM
    I need to create some annotation families, and I cant figure out how to make lines visible over a filled region or masking.
    Take this picture as an example.
    I need to draw this symbol which should appear white in its interior. In order to do that, I make a mask or filled region, and then, when I draw the lines over the circle, they appear hidden.
    How can I solve that?
    Thanks
    Attached Thumbnails Attached Thumbnails How to make lines visible over mask or filled region?-captura-de-tela-2015-05-09-c3a0s-18-02-18.png
    June 29, 2015
    91
    12:57 PM
    I guess Annotation families are not the ideal template for this kind of symbol. Try a Generic detail item instead, as the one I just created trying to replicate your image...
    Attached Files Attached Files
    January 27, 2016
    7
    11:57 AM
    asd ad as
    Quote Originally Posted by asintoras View Post
    Thanks! Yes, that's excactly what I wanted, but I cant find where to create this genereic detail item that you said..
    June 29, 2015
    91
    12:57 PM
    I am sorry for the late reply. I was pointing you to ->"New Family->Generic Detail Item" template. Start a new family and look for this template, which would give you more flexibility to add filled regions.
    Hope this helps!
  1. Mask a diagonal-up-hatch-filled-region
    By mdomer in forum Architecture and General Revit Questions
    Last Post: January 13th, 2016, 02:59 PM
  2. Masking Region to Not Mask Model Text
    By Lisa in forum Architecture and General Revit Questions
    Last Post: March 5th, 2014, 09:15 PM
  3. Building Coder: Create a Filled Region to use as a Mask
    Last Post: July 6th, 2013, 09:18 AM
  4. Replies: 0
    Last Post: March 7th, 2013, 05:45 AM
  5. Replies: 0
    Last Post: August 17th, 2011, 10:20 AM
Tags for this Thread
