Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree5Likes
Thread: Metal Grate
    October 20, 2016
    NC
    14
    02:06 PM
    Metal Grate
    Any suggestions on creating an adjustable metal grate family. I successfully made one using arrayed extrusions, but it is too memory intensive. Something like curtain grids or profiles...
    August 19, 2011
    New Hampshire
    473
    01:06 PM
    What kind of grate are we talking about? Honeycomb or something else?
    October 20, 2016
    NC
    14
    02:06 PM
    Metal bar grate as shown.
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,302
    11:06 AM
    What is the grate being used for?
    UKN
    UKN is offline
    Member UKN's Avatar
    February 16, 2011
    Las Vegas, NV
    56
    10:06 AM
    Personally I don't model grates unless it's specifically shown in a rendering view. For documentation purposes I just do a transparent floor with a surface model pattern to show the grate and then vertical lines for the cut pattern.
    cganiere, Mike Ferrell and maxdig like this.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,124
    10:06 AM
    Quote Originally Posted by cvestal View Post
    IMO, simplest way is with a curtain wall or curtain system (for vertical or horizontal grates). Like this
    8,582
    12:06 PM
    Model pattern and/or Material, even if it's being rendered. That's even more *fine* than louvers (which I model as custom families).
    Dave Jones's Avatar
    4,124
    10:06 AM
    out of curiosity, what would you apply the model pattern or material to? It would have to be something transparent so one could see through the grating. Sorry if this is a stupid question, I don't work with model patterns or materials applied to faces at all but I can see possibilities for this process in some of the things that I do
    August 19, 2011
    New Hampshire
    473
    01:06 PM
    Dave, generally the grate would be modeled as just a simple box extrusion within a frame. The box, functioning as the grate pattern, would have a crosshatch line model pattern applied to it with the dimensions of the grate design. The material would be transparent in shaded view, but use a material cutout for rendering purposes so one could 'see through it'. Think chainlink fencing or mesh screening.
    cganiere and Twiceroadsfool like this.
    Dave Jones's Avatar
    4,124
    10:06 AM
    Quote Originally Posted by Andrew K View Post
    Thanks Andrew. What is "material cutout"? While I do no rendering at all I need this grate to look correct in 3D views. This is what I get using a GM box with a cross hatch model pattern applied to the face (on the right). The grate on the left is a curtain system with 1/2" x 1" bars set with Max Spacing in both directions. That's the look that I need to end up with.
  1. Metal Roof
    By MARIA1993 in forum Structure - General Questions
    Last Post: January 6th, 2017, 06:56 AM
  2. Floor Based Family: Floor Grate. Works fine UNTIL I array the grid
    By doni49 in forum Architecture - Family Creation
    Last Post: August 19th, 2015, 09:36 AM
  3. metal wall framing
    By elton williams in forum Architecture and General Revit Questions
    Last Post: June 19th, 2012, 01:10 PM
  4. Metal Cutout
    By GMcDowellJr in forum Rendering and Gallery
    Last Post: February 18th, 2012, 10:54 PM
  5. Where did my metal deck go?
    By LeanneZ in forum Structure - General Questions
    Last Post: November 3rd, 2011, 02:45 PM
