Results 1 to 2 of 2
Thread: Double Sided See Through Fireplace
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,605
    01:10 PM
    I'm stumped on what I thought was a relatively simple thing. I need to make a see-through fireplace and can't figure out how to get everything to cut the related walls correctly. What I'm trying to get is to have the fireplace unit cut the studs in the wall but not the GWB, except at the see-through firebox. The unit (Napoleon Vector™ 50 - LV50 2) has a big rough opening that the drywall will cover and a smaller firebox.
    The studs are 16.75" out-to-out which is too far away to join the walls and I can't figure out the correct combination of openings & voids to get everything to cut properly...
    Attached Thumbnails Attached Thumbnails Double Sided See Through Fireplace-fireplace.png
    August 19, 2011
    New Hampshire
    473
    01:10 PM
    We have the Vector on ARCAT.
    The way to go about it is to have two voids. One void sticks out from the wall to always cut out the opening. The other is constrained to only cut out around the box of the fireplace.
    EDIT:: Plus, it's going to depend on how you modeled your walls. A "cuts with voids" solution may work better for you.
    EDIT2:: Okay, we don't have the see-thru version. Looked over that part.
  1. 3 Sided Triangular Pyramid
    By DanielHurtubise in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 18th, 2016, 09:29 PM
  2. How to make or where download a 6 sided bay window
    By giannifrullo in forum Architecture and General Revit Questions
    Last Post: May 28th, 2016, 09:13 AM
  3. Shades of Grey: STOCK OFFICE FIREPLACE
    By Shades of Grey in forum Blog Feeds
    Last Post: October 8th, 2015, 02:45 PM
  4. double two sided swinging door
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: May 27th, 2013, 11:11 AM
  5. Fireplace
    By muttlieb in forum Rendering and Gallery
    Last Post: June 6th, 2012, 10:09 PM
