Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree10Likes
Thread: Family use
    October 18, 2016
    26
    02:39 AM
    Family use
    Hey guys!
    A quick question :
    Are you guys using Revit provided models from manufacturers ?
    If so, what do you use them for ? ( for example, as example, or to render, to see if they fit , ... )
    Would help me a lot by answering this one!
    Thanks in advance,
    Alexandre
    Member cganiere's Avatar
    January 5, 2011
    Orange County, California, USA
    189
    06:39 PM
    Many manufacturers and industry groups provide models. Yes, I use them, but not always.
    December 21, 2010
    C.LONDON
    4,175
    02:39 AM
    Not if I can help it.
    Which basically means never.
    8,825
    08:39 PM
    Practically never. The one time recently i recommended to a client that we use (start with) the manufacturers library to save time and money, it ended up costing us a lot of time, and a lot of money. Dont bother.
    Nurlan likes this.
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,316
    07:39 PM
    I avoid it whenever possible, but if they are decent models will occasionally use lights or specific equipment if I don't have an alternative or time to make one. Usually I need a more general item that is flexible to adapt to the current basis of design.
    I will download and look at specific families to acquire dimensions/relationships that are not documented elsewhere when building a family.
    Manufacturer models seem to always have something wrong with them (such as extra lineweights, 2d representation, cad imports...), and/or are too specific for my needs.
    JWR and cganiere like this.
    July 14, 2016
    55
    02:39 AM
    If I find a good quality one, definitely yes. More often than not they are unfortunately very badly made
    Senior Member sdbrownaia's Avatar
    December 20, 2010
    916
    09:39 PM
    The key here is to know how to review the content, PRIOR, to loading it in your project. And what type of content is it. furniture or other items that stand alone, ie don't host or need to play well with others are easier to re-use from mfrs'. But things like doors, curtain walls, lights, etc. that are hosted will most likely cause you pain unless you review them carefully and make sure they match your companies standards for family construction.
    Karalon10 likes this.
    May 3, 2012
    1,274
    03:39 AM
    I only use manufacturer content if I want a nicely modelled 3D object, otherwise just the overall size and the information contained in the family is more important.
    Make an empty template family, with all the standard functionality, parameters, naming conventions etc. etc. that you want, then put any families from external sources inside this template. Then you can use the 3D model in your project and have everything else work predictably.
    JWR, Nurlan and cganiere like this.
    October 18, 2016
    26
    02:39 AM
    Thx for the answers guys!
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    07:39 PM
    Depends on their use. If its for rendering purposes and you just need some placeholders in there temporarily, I typically go for the realistically modeled ones. C'mon guys, manufacturer's have gotten better over the years, but yes, I can't remember the last time I downloaded one from their sites because I end up with a "CAD-add" instead of a natively modeled element. I think that's beat a lot of the first comers to cringe when they think of downloading from a manufacturer's site. The most recent one I got was from Herman Miller and it was nicely done, native in Revit, not a huge file, rendered incredibly well. It IS possible to get the best of both worlds.
    cganiere and Allu like this.
  1. Replies: 0
    Last Post: August 10th, 2016, 06:15 AM
  2. Replies: 0
    Last Post: March 27th, 2016, 07:18 AM
  3. Replies: 0
    Last Post: September 27th, 2013, 06:45 AM
  4. Can't change family origin point, family loads into project as hidden lines
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 1st, 2013, 04:51 PM
  5. Replies: 16
    Last Post: April 26th, 2012, 09:16 AM
Tags for this Thread
