Donate Now Goal amount for this year: 3000 USD, Received: 2460 USD (82%)
Results 1 to 8 of 8
Thread: Non-reporting parameters
    Member DesignApparatus's Avatar
    July 20, 2011
    San Diego, CA
    176
    12:13 AM
    OK, I must not be seeing the forest for the trees so to speak. I took an existing furniture family and modified it. No the reporting parameters (LENTHG, WIDTH, HEIGHT, & SEAT HEIGHT) will not report to a schedule anymore. Any ideas? I cannot seem to attach the family to this post...getting error message.The furniture family, before I edited it, had "shared parameters" but mine disappeared. I tried to re-create them but when I check the "shared parameters" box, everything grays out. I am confused and am not sure where I made a wrong turn.
    Member Darius's Avatar
    May 6, 2013
    466
    03:13 AM
    in the modification did u change the parameters from instance to type base?
    July 20, 2011
    San Diego, CA
    176
    12:13 AM
    The file I started with used "shared parameters" and "type" (not instance)....so I kept on with that. Now I look at the file and if I check the "shared parameters" box, it grays out all of the other boxes and will not let me edit it.
    July 20, 2011
    San Diego, CA
    176
    12:13 AM
    Here is a copy of the family file if anyone feels like investigating.Couch Full-size BC 106 in.rfa
    May 6, 2013
    466
    03:13 AM
    So this is way late if you want to schedule parameters they need to be instance based
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,497
    02:13 AM
    Quote Originally Posted by Darius View Post
    No they don't.
    You can schedule either Type or Instance parameters, but they must be Shared Parameters.
    I'll bet the recreated parameters were Family Parameters.
    Another thing people often don't understand is the just because a Parameter has the same name doesn't mean it IS the same Parameter.
    Unless it was selected from the same Shared Parameter file, a new parameter WILL be different and will not schedule the same.
    Coeur d Alene, ID
    4,256
    12:13 AM
    To add to Dave's post....LENGTH and Length are two different parameters too.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,240
    12:13 AM
    and, as we all know LENGTH (or Length) matters
  1. reporting parameters that function?
    By billiam in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2014, 08:03 PM
  2. adding reporting parameters
    By karpov005 in forum Architecture - Family Creation
    Last Post: November 6th, 2014, 12:35 PM
  3. Parameters reporting '0' in tags and schedules
    By joshr in forum Architecture - Family Creation
    Last Post: April 4th, 2014, 12:19 AM
  4. Reporting Parameters and Ceilings
    By stellra in forum Architecture - Family Creation
    Last Post: November 5th, 2013, 11:32 AM
  5. reporting parameters
    By Kevin McCurdy in forum Architecture - Family Creation
    Last Post: December 15th, 2010, 10:37 PM
